RV.Net Open Roads Forum: Travel Trailers: Have you balanced your TT tires?
 > Have you balanced your TT tires?
SpoiledRotten
Central Mississippi
Posted: 05/16/08 07:49am Link  |  Quote  |  Print  |  Notify Moderator
The tires on my 5er are balanced. Just as important as balancing your TV tires. You just don't feel the affects of unbalanced like you do with the TV, but they still wear uneven and create rattles within your rig. I would suggest getting it done.
Just the 3 of us...SpoiledRotten, TotallyRotten, and ALittleRotten
2000 F-250 Lariat, CC
7.3 PSTD-Superchipped
2005 33RL2 New Vision - AKA "SpoiledRotten"
2000 Jeep Wrangler Sahara Edition
skipnchar
Topeka Kansas USA
Posted: 05/16/08 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Never have balanced or rotated any of mine but that MAY explain why I generally have to replace them after only 40,000 miles or so. Good luck / Skip
tvman44
Southwest Louisiana
Posted: 05/16/08 08:08am Link  |  Quote  |  Print  |  Notify Moderator
I had the tires balanced on our 5er and it seems to make a little difference, hard to tell from the truck. But in my opinion it has to make a difference, you know what the TV does with an out of balance wheel, you are just not riding in the trailer to feel it like the TV. Glad I did it.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
dcooper
Abilene, TX
Posted: 05/16/08 08:38am Link  |  Quote  |  Print  |  Notify Moderator
Three years ago as I was readying my new TT for its first outing, I noticed that the valve stems on the wheels were cracking and appeared ready to fail. I also noticed they weren't balanced so I took it to Sears and had all five tires balanced and new metal valve stems inserted. The tech said that the old stems were not the right type for the high pressure trailer tires. So after three years and many miles I'be had no tire problems at all. I inflate the tires to 65 lbs and this spring when I dewinterized it, I checked the pressure in the tires and they had all uniformly lost only about 3 lbs over the winter.
ScottG
Bothell Wa.
Posted: 05/16/08 08:48am Link  |  Quote  |  Print  |  Notify Moderator
Like others have said, I feel anything that spins s/b balanced especially tires. Heck, trailer tires are junky enough without bouncing them down the road until they beat themselves to death.
Scott, Grace and Wesly
2003 Dodge 3500 4x4 Cummins (lightly bombed),
H4Adventures
Minot, North Dakota
Posted: 05/16/08 09:01am Link  |  Quote  |  Print  |  Notify Moderator
New ones I put on last week are balanced.
2007 Zinger ZT30BH
2008 GMC Sierra 2500HD CC, 6.0/4.10
2004 Chevy Trailblazer
2003 Tracker Avalanche, 150EFI Merc.
JJBIRISH
BUTL;ER, PA, USA
Posted: 05/16/08 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Tip #9: Remember to have your tires rotated and balanced according to the tire manufacturer?s recommendations. from the Dexter web site...
Tire Balance and Wheel Alignment
To avoid vibration or shaking of the vehicle when a tire rotates, the tire must be properly balanced. This balance is achieved by positioning weights on the wheel to counterbalance heavy spots on the wheel-and-tire assembly. A wheel alignment adjusts the angles of the wheels so that
they are positioned correctly relative to the vehicle’s frame. This adjustment maximizes the life of your tires. These adjustments require special equipment and should be performed by a qualified technician... taken from a major mfg web site...
I don't believe I have ever read to not balance tires and wheels on any official web site...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
dodge guy
Chicago, western subs.
Posted: 05/16/08 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Worked at a cab co. when I was younger. we never did balance any of those tires and being taxi`s they never had any type of vibrations, even the newer ones we would put in the fleet!
I even put tires on one of my own cars without balancing them and it rode just as smooth as the worn out tires I took off!
most of the time when you balance a tire your talking about adding a weight of less than an ounce. you will never feel that nor will it cause any damage!
Wife kim
Son brandon 6yrs
Daughter marissa 5yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
smkettner
Vladivostok, Russia (temp)
Posted: 05/16/08 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Less than an ounce and balanace is probably not neeeded. However you only know it is less than an ounce by putting it on the machine and then you may as well make it right.
Dixonmatco
Santa Rosa, California
Posted: 05/16/08 11:35am Link  |  Quote  |  Print  |  Notify Moderator
Balance.. Yes.. If it rotates, I balance it. (if at all possible)
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
