RV.Net Open Roads Forum: Sanitizing fresh water system for the first time...
 > Sanitizing fresh water system for the first time...
Dixonmatco
Santa Rosa, California
Posted: 05/16/08 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
You need to sanitize a NEW FW tank on a new RV??
I certainly never did mine.. A simple flush was all I ever did. I am on water from a small local water company and it has a bit of chlorine in it already so I guess that must be enough, as I am just fine after 3 seasons of using the trailer. I do always flush and refill before each trip.
Those additives to help remove the plastic taste seem to work, as I have heard from some tha use it.
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
Roy T
Dodge City, Kansas
Posted: 05/16/08 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
I've seen several people recommend using bleach. However, none of them seem to agree on the ratio of bleach to water. Must be somewhere that has the ratio everyone agrees upon.
MaddogBC
Kelowna BC
Posted: 05/16/08 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
1/4 cup per 15 gallons I have seen used in many pages and posts, much more so than any other ratio. It's what Jayco recommends for their trailers. Worked quite well for us, the thought of ruining a vacation with a sick family because I was too lazy to do an hours work just doesn't sit well with me
Hornet28BHDS
Parker, PA
Posted: 05/16/08 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
MaddogBC wrote:
I sanitized with bleach for 4 hours. 1/4 cup per 15 gallons of freshwater capacity.(too long can damage plumbing) Then let it sit with a vinegar solution for several days, I used 2 gallons for my 45 gallon system. I drove around a bit to shake it up during the vinegar stage. I then had to rinse twice to get rid of the odd taste. All this was described very well in my owners manual.
I have no experience with any FW additive products and frankly I'd be hard pressed to trust anything but Bleach. It's how my daddy cleaned the water system for the little town we grew up in
To properly drain the system you have to drain both the tank and all your lines. You should just have to use your low point valves, and the drain on the or near the FW tank. Check to make sure your hot water tank is not bypassed and is filling and emptying. I flushed all my water lines the old fashioned way into the grey tank.
Good luck, it's not a quick easy job
Rob
That's the way to do it!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
