RV.Net Open Roads Forum: How hard is it to Rotate a window in TT
 > How hard is it to Rotate a window in TT
bamcote
Freedom NH to Crossville TN
Posted: 05/16/08 12:19am Link  |  Quote  |  Print  |  Notify Moderator
The slide window over my sink is almost worthless when the door to the TT is propped open because it covers the screen area. Can you rotate or flip the window so that the screen area is not behind the door and how much trouble am I asking for before I ask DH to change it?
DH, DW and 2 chats-Butt and Mocha the Siamese sisters
Molly the Maine Coon kitten
Mina the rescue mutt
2008 Fleetwood Bounder 36Z
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 05/16/08 12:43am Link  |  Quote  |  Print  |  Notify Moderator
I believe they may be "this end up" specific, as there are drain slots on the bottom to let out condensation. If the "weep holes" are on the bottom of the slide area AND the top you're ok to flip it. But you can look here! This is the Hehr website, they make a lot of rv windows and should be able to help.
Geozzz
South Jersey
Posted: 05/16/08 04:13am Link  |  Quote  |  Print  |  Notify Moderator
If you flip it, while traveling in the rain, the water will enter between the panes because the overlap will be in the wrong direction.
Kathy & George Zimm
Mickleton NJ
2006 Coachman Epic and 1 Sheltie
bamcote
Posted: 05/16/08 06:59am Link  |  Quote  |  Print  |  Notify Moderator
Good point! Never thought of that, Thanks for the info.
