RV.Net Open Roads Forum: Fifth-Wheels: Trailer level
 > Trailer level
goin2themountains
Aztec, NM
Posted: 05/16/08 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
If you don't want to mess with it, send it to me. Last trip out traveling solo, I pulled into a pull through space, and was in and out of the pickup 3 times moving back and forth a couple feet each time to find the most level side to side spot, with my small levels at the corner of my 5er, in the space. Would have avoided all of that with a large level on the pin box. Take a small level inside, play with it till you are happy it's level, then stick that puppy to the front.
Puller: '04 HD2500 4x4 SB,EC Duramax/Allison. Airaid intake, 4in. exhaust turbo back, ORU leveler.
Pullee: '02 Keystone Cougar 276EFS Reese 16k w/ slider.
(map is for current 5er only)
amxpress
Clayton, NC
Posted: 05/16/08 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
I wanted to get one, but DW said I didn't need it. Yes dear.
Now, she is in charge of going into the trailer and checking it with a level.
Also, if it's not level after I unhitch, I don't get blamed.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2008 Palamino Sabre 31RKTS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Travel light, leave the M-I-L at home.
HUTCH45
NORCAL
Posted: 05/16/08 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing like having the "BIGFOOT" Auto-Leveling system, (ahem)...drop front legs...unhook TV...push a button...pop a beverage, (gloat-gloat-gloat)......
"HUTCH"
'07 SILVERADO 3500HD 'CLASSIC' DRW - CC - 4 X 4
'07 NEW HORIZONS 34' 5th.Wheel 'MotoMover'
'06 HONDA 106hp.VTX1800 w/'HANNIGAN' Sidecar
Mopardan
Arkansas
Posted: 05/16/08 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Well I think I'm gonna put it on there. May have to hook up and find a level spot because where I park it probably is perfectly level. I will put a small one on the side for front to back. Next weekend will be our first trip out with this RV. Thanks for everyones input.
lynlou14760
Olean, New York
Posted: 05/16/08 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Darn, why didn't I think of that? I think it's a great idea, and could save a leveling the unit. Most of us can get them level in one try (after reading the smaller levels), and this would save an entire step.
newk
Gillette, WY
Posted: 05/16/08 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
I wanted to get one of those big ones when I bought my current 5er, but the dealership didn't have any good sized ones. I can *barely* see the small one I have now, mounted with double-sided tape on the front -- if it's daylight. My eyes seem to be going fast, so I'm going to be certain to get a bigger bubble the next time.
When mounting the level for front-to-back, be sure you put it where you can see it as you raise and lower your landing gear. The first 5er I had, I mounted the level where I couldn't see it and reach the switch at the same time. **DUHHHHH**
Mopardan
Arkansas
Posted: 05/17/08 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
"Quote"
I glad you mentioned that!
 > Trailer level
