BarbaraOK
Livingston, Texas, USA
The advantage of a mail order pharmacy is you usually can get 3 months worth at one time - less hassle for maintenance meds. Our insurance is designed to push you into using the mail order as it is cheaper all the way around on most meds. We can only get 30 days at a walk-in pharmacy and each time have to pay a deductible, but can get 3 months with the mail in for the one deductible. We've been very happy with Medco. You can even use them if you don't have a specific insurance company paying for meds.
Barb
Barb & Dave - full-timing
Traveling catpanions Kit (age 17) and Shadow (age 10)
Figment II (2002 Alpine 36 MDDS)
Mischief (2004 Subaru Forester Toad)
FMCA - F337834, SKP #90761
http://homepage.mac.com/barbaraok/
Our blog
mockturtle
Northwest
BarbaraOK wrote: The advantage of a mail order pharmacy is you usually can get 3 months worth at one time - less hassle for maintenance meds. Our insurance is designed to push you into using the mail order as it is cheaper all the way around on most meds. We can only get 30 days at a walk-in pharmacy and each time have to pay a deductible, but can get 3 months with the mail in for the one deductible. We've been very happy with Medco. You can even use them if you don't have a specific insurance company paying for meds.
Barb We have Medco, as well, and are very happy with it.
2000 Aerolite 19RB TT
1996 Chevrolet Blazer 6 cyl. 4WD
This car used to be our toad, now is our TV!
trkrhelp
On The Road
We use a combination of CVS and mailorder. The controlled are a little more difficult but can be handled with a little planning.
last
edited 05/17/08 05:33am by trkrhelp *
View edit history
John Ewing
2007 Allegro Bus 42QRP ("TisIt")
2005 Sportster/HydraLift ("Dinky")
2002 Miata toad ("Mellow Yellow")
www.jandse.com
FMCA 104106
What goes around comes around - always treat others the way you'd like them to treat you.
Pete D
Washington
I used MedCo when I was full timing and I could either have them send it to me directly or send it to my mail service to be forwarded the next time I did a 'scoop and send'. If I needed something right away but also ongoing, like change in thyroid meds, I would ask Doc for two prescriptions, one local to get started and one for MedCo for maintenance.
Hard part was finding a Doctor's office that would take a one-time patient.
I carried copies of all my medical records, including a self-compiled summary record of lab test history.
1998 Ranger 4.0 4x4
1991 Scamp 13'
Rick and Toni
on the road
We use Walgreens. You can access your prescriptions online, make your order, choose the store where you want to pick them up, and select the date and time for pick-up. I think it's much easier to do it online than to punch in all those numbers over the phone. Toni
Rick and Toni
2004 Coachmen Sportscoach Limited Edition
1 Westie
southbound
Forsyth GA
Find out before you go on the road if you prescription is a controlled drug.Tenn Stud has it right.
Southbound
DarkRubiTJ
Livingston, Tx.
Walgreens and CVS might be great but they aren't in all areas of the country. You need to see if they have stores in the areas you are going to be when your current refill runs out. You might have to drive a couple of hundred miles or more to get your prescription filled. It has happened to us and that was using Sams/Walmart. We were in a place where the closet Walmart was 110 miles away and there wasn't a Walgreens or CVS in the state. The nice thing about Walmart/Sams is that your prescription will cross over from either store, and even if you aren't a Sams member you have access to the pharmacy, because it's a federal law that you must be allowed in to use the pharmacy if you desire to.
trkrhelp
On The Road
What state were you in where there wasn't a CVS or Wallgreens in the state?
Pete D
Washington
Don't seem to be any CVS in Washington, Oregon, Idaho. In fact, their store locator only lists 41 states...
Walgreen's isn't as easy to use, but they don't have one in Alaska.
OTOH, there are Wal*Marts in Newfoundland, out on Kodiak Island, etc.
trkrhelp
On The Road
You're right and thanks for pointing that out. CVS, which we use, is not in all the states, but it does have a simple way to order online and we always get things far enough in advance to avoid a problem so it should continue to work for us.
Just as a point of interest for those with Class II and up prescriptions, you can fill those online through CVS and eliminate the problem with transfering the prescription from state to state. The Dr calls in, or you mail in the original prescription, to their 800# and then you can fill the prescription online.
