There are a few small cracks in the caulk on my roof. What can I use to fill/seal them? The manual says to repair them, but does not say what to use or what was used. My unit is just 1 year old so all in all the caulk is in good shape.
Dave
2007 Jayco 23B
2000 E150 Ford Club Wagon 5.4 w/ tow pkg
Equalizer hitch, Kelsy brake controller
1997 Coleman Sunridge- Served us well for 11 years!
I'm hoping for a good answer to the same question. My '06 Jayco MH has cracks in the really thick caulking they use all over the roof penetrations. I bought a tube of Dicor for rubber roofs but haven't opened it up yet, but I think this is the right stuff to fill in the cracks. It also comes in a gray color that should match the Jayco caulking pretty well.
edited 05/16/08 10:14pm by jbbrick *
Check the tube of dicor to meake sure it is the stuff that is compatible with rubber roofs. It should state so right on the tube. If so that is what I have always used to go over the cheap/sloppy caulking areas done at the factory.
