RV.Net Open Roads Forum: Tow Vehicles: Diesel hybrid technology
Search only in Tow Vehicles
 > Diesel hybrid technology
Page of 6
jimmyfred
Tx
Posted: 05/16/08 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
...........Take an already fuel efficient , diesel powered truck , add A S--t load of extra batteries , big electric motor , extra transmission components , a godawful amount of Electronics to monitor and control all this UNnecessary equipment , and then call it fuel efficient . What a load of******that is ! , jf
1999 F250 PSD , 4x4
1999 Travel Supreme RLSS , 33
Reese 20k Hitch
Prodigy , etc .
ib516
Up here!
Posted: 05/16/08 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
What is different from that vs a Toyota Prius? Already fuel efficient, added electronics, etc.
Obviously they decided against it for some reason. But I personally don't think it would be such a dumb idea. Expensive - likely, but dumb, no.
2004 Cougar 301 BHS 6580# Dry, 9000# wet, 9600# GVWR)
2007 Dodge/5.9L Cummins 3500 SRW Megacab 4x4/3.73
Hypertech Max Energy
"MEGACASPER" 10100# GVWR, 5200# FGAWR, 6200# RGAWR
PICTURES
ELIM 3000 Gen
Collision Reconstructionist
MEGACAB CLUB MEMBER #1
edfoxx68
usa
Posted: 05/16/08 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
david_42 wrote:
You only get better mileage in hybrids when you reduce the size of the main engine. So, if you were willing to cut back to 100 hp max, you'd see an improvement. The diesel hybrids that are being used get about 40% better city mileage, but very little improvement on the highway. Takes raw power to push a 40,000 pound box at 80!
I understand what your saying, but I have to disagree about the size of the engine. Electric assist motors we're banned by motor sports because they were an un-fair advantage. They got more power and used less fuel.
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/16/08 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
Kenneth wrote:
SoCalDesertRider wrote:
I would call a diesel-electric locomotive a hybrid. Think of a hybrid. What is it? It's a small internal combustion engine that drives a generator that powers an electric motor that powers the car. That is, for all practical purposes, how a locomotive operates. I would call the diesel-electric power systems in locomotives and ships the pioneers of the use of hybrid technology that resulted in hybrid cars.
In any event, if a diesel hybrid pickup or suv can be built for public or personal use, I'm all for it. Gasoline hybrids are being made. I dont see why a diesel hybrid is so out of the question. It's only a different fuel powering the internal combustion engine.
If the generator provides enough juice for the electric motor in continuous operation, it doesn't matter about the batteries.
Whoa, you're way off base. Nothing small about the engines in a locomotive. They're the biggest one or two engines that can fit there. I've never heard anyone else call them a hybrid, just diesel-electric.
I've worked on steam turbo-electric drive ships. These were WWII tankers that had electric drive because the country could not make enough gear sets*. The main turbine powered a generator, the generator powered a 6000 hp main propulsion motor when underway, and powered cargo pump motors in port when discharging cargo. These were less efficient (higher fuel consumption) than a geared turbine ship with direct geared drive to the propeller shaft, but it was the best we could do at the time. It wasn't a hybrid, either. Some modern passenger ships are diesel-electric drive for a couple of reasons, mainly for layout so they can cram more machinery into tighter spaces and have more passenger rooms to sell.
The point is that the hybrid vehicle relies on both the engine and the battery electric motor for power when it needs a lot of power. When the batteries are depleted, all you have left is a smallish engine, and that won't please most folks towing a heavy load up hill. Electric drive is very different. It is designed with the engine providing full power to go as fast as the guy buying the fuel wants it to go. The generator is just a different means of power transmission.
*I just learned that the U.S. can't even build the wind turbines that are beginning to generate substantial amount of our electricity. We can build about half of a unit. We can't even build the gearing. We've lost that much industrial capability.
I agree the diesel engines in locomotives are huge, but much smaller than they would have to be if the train was powered solely by diesel engines. The term 'small' is all relative here. Whatever you want to name them, the idea is the same- use an internal combustion engine to power a generator which powers an electric motor that drives the vehicle. If 'hybrid' doesn't taste good in your vocabulary, that's fine, use whatever name you like. It tastes fine in mine.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
pronstar
The LBC
Posted: 05/16/08 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Look up "series hybrid" and "parallel hybrid" and all will be revealed...
On a side note, I'm going to build an electric truck with an electric-driven alternator that will make it's own energy.
2007 Dodge Ram 2500 CTD 4x4/QC/LB
2008 Stellar 23' Toy Hauler
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/16/08 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
LMAO!! Have you invented the perpetual motion machine? What about the car that runs on water?
fickman
Fort Worth, Texas
Posted: 05/16/08 11:04pm Link  |  Quote  |  Print  |  Notify Moderator
On this forum we obey the laws of thermodynamics!!!
2005 Chevrolet Silverado 2500HD Crew Cab SB LS 6.0L 4x4 4.10
DW, DD (born in May, 2007), and me
edfoxx68
usa
Posted: 05/17/08 12:07am Link  |  Quote  |  Print  |  Notify Moderator
Should have known better than to discuss fuel saving with RVer's.
dgreen1069
Bristow, VA
Posted: 05/17/08 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Now that's funny
2003 Excursion Limited
6.0 PSD/5sp Torqshift/3.73 Limited Slip
2003 Potomac 30 EBS
Hensley Arrow
eightballsidepocket
San Jose, California, USA
Posted: 05/17/08 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Anyone remember or are you familiar with WW2 submarines? They had diesel power for running on the service and massive batteries for running submerged and silent.
The Nazis even came up with the "snorkel" so that they could stay submergered and draw air down and run their diesels to charge their massive battery pack.
Anyway, this splitting hairs over what is trully "hybrid" is a little redundant IMO. First of all, the very definition of hybrid means;
From Merriam Webster Dictionary
Main Entry: hy·brid
Pronunciation: \?h?-br?d\
Function: noun
Etymology: Latin hybrida
Date: 1601
1: an offspring of two animals or plants of different races, breeds, varieties, species, or genera
2: a person whose background is a blend of two diverse cultures or traditions
3 a: something heterogeneous in origin or composition : composite b: something (as a power plant, vehicle, or electronic circuit) that has two different types of components performing essentially the same function
Unless Merriam Websters is behind the times, I would say that a diesel/electric locomotive is and would be defined as a form of hybridized power, even though the internal combustion powerplant is massive in comparison to what a Prius or Honda Civic hybrid utilize to charge their respective battery packs.
As mentioned earlier, WW2 submarines utilized a hybridized system of power. In essence they did keep their batteries charged via their diesel engines during normal surface running. In most cases, submerged, they ran strictly on battery supplies......I would assume that prop shafts were driven by large electric motors then. Now maybe they had a way of changing their mode of direct drive to the prop shafts when using diesel power and didn't utilize a final electric motor driven by a generator that was driven by the diesel powerplant, but I'm sure some Navy vets could fill in the details there.
Hybrid seems to mean the merging of or combination of two or more. So in the case of hybrid power, I would say that any vehicle that is moved in water, rails highway, or the air, or is used as a stationary powered tool that has two modes or sources of power that work both together and possibly separately to power the vehicle/too, would be defined as hybridized power.
* This post was edited 05/17/08 01:23pm by eightballsidepocket *
Regards, Eightballsidepocket
2005 Dodge Ram 2500 SLT 4x2 Quad Cab, Cummins, 48RE Tranny, Lg Bed, Line-X Spray-on Bed Liner.
06 T25BS Komfort Trailblazer TT
"If you can't say it in person, it isn't worth saying while hiding behind an anonymous P.C.!"
Page of 6
