Adam-12
Northern CA
My instructions said to "purge" the brand new tanks of air before 1st use. How in the heck do you "purge" the tanks of air?
Especially now with the new safety valves that won't open up unless it's connected to a hose etc...
Thanks.
2008 Silverado 2500HD Duramax/Allison DIESEL/4x4/CC/Z71
2008 33ft. TT/BH-Super Slider
Parallel Honda EU2000i's
Yaesu 857d
Dipoles/random wire/tuners
Fishing equip.
Quads
Life member: NRA
ALCOHOL
TOBACCO
FIREARMS!
javaseuf
Southern Cal
You fill the tank with a "squirt" of propane and then open the vent to purge the tank. When it's empty, continue to fill. This is how we did it where I worked and we had no problems.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
RJsfishin
Winston Or.
Just fill it. I've never purged one in my life. And I filled lots of new ones. And when they wasn't lookin I even filled one that I built myself.
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
downtheroad
Tumbling Waters, Washington
You don't purge it.
Take it to a propane supplier and tell them it's a new tank. They will know that it needs to be purged and will do so before filling it for you.
I suggest a full retail propane outlet..not a gas station where the attendant runs out and fills propane between selling beef jerky, beer and cigarettes.
GMC Duramax/Allison (LBZ)
08 Komfort 277TS Our Rig Pic
Reese Dual Cam HP
Kenneth
Washington, the state
The cylinders are filled with dried air to prevent internal rust. One shop in this area actually connects a vacuum pump and evacuates all the air out. Another just bleeds out this pressurized air, then fills it as usual.
Rollincool
Always Rollin
Adam-12 wrote: My instructions said to "purge" the brand new tanks of air before 1st use. How in the heck do you "purge" the tanks of air?
Thanks.
New tanks are ALWAYS supposed to be purged. They should add some methanol (methal alcohol) then purge it with some mercaptan.
Now does everyone do this? I have never seen it done at small local filling stations. More than likely a propane company, (the big ones) will do this. The reason for the purging is to rid all air and moisture. The air and moisture kill the smell of the mercaptan.
If you don't smell the mercaptan, you will NEVER smell the gas.
By the way, it's a fact that women smell the mercaptan additive before men do.
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Conquest Super C 6349
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
My 70's Show - Tom Kent Radio Network - Kā¢Hits 106.7
Dave H M
IL
I have always just had them filled and noticed no diference.
There was one post about putting in a little and then opening the valve to empty it. I don't know how long ago it was that you could have a tank filled that would discharge when the valve was opened. Maybe two generations back. I guess you could jury rig something to open the valve in the outlet, but like I mentioned, I am well into social security and have always just had new tanks filled.
bkd148
Spanaway, WA.
Unless you purge the tank it will never be capable of holding the full or correct amount. You need to put a vacuum on it just as they do in air conditioning systems to balance the presures. The mercaptan is in the propane and not the tank. I know this because I worked for a large propane company here in the Puget Sound area for 2 years.
You only put methanol in the larger tanks not the little 20&30 pounders.
edited 05/16/08 08:25pm by bkd148 *
2002 Beaver Patriot Thunder
Cat C-12 455hp. 6spd. Allison
2002 Jeep Wrangler Sahara
jdgreen42
Silsbee, TX 77656
Listen to " downtheroad". He has the correct answer.
Don
RJsfishin
Winston Or.
Listen to yourselves,....then you will know its all BS !
You all said its done to get the air out. So Just what do you suppose any tank is full of everytime it runs out of propane ? So now you're going to "purge" every tank that runs out of propane?,......yeah right !
The one that says the tank will never fill to its normal capacity unless you get it purged,......well that one beat them all. I've proved that wrong hundreds of times.
