RV.Net Open Roads Forum: Class A Motorhomes: Brake controller
 > Brake controller
mikeyjeeper
southern california
Posted: 05/16/08 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
I have just puchased a 2004 Dolphin lx motorhome. I want to put an electric brake controller on it for my trailer, but am having trouble finding the plug for it under the dash anywhere. Has anyone else installed a controller and is this coach pre wired for it?
PCAracer
Oklahoma
Posted: 05/16/08 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
I am sure this varies from coach to coach but I know mine did not have a plug under the dash. My Dealer installed mine and they had to tap into the wired under the dash. Their first attempt did not work. Took it back and the corrected it at their expence. Works perfect now. It would probably be worth it to take it to your dealer if they are good. If not, with out a good wireing diagram for under your dash, it may be tough.
Do you have a trailer hookup in the back? Look under and see if you have a wire going to the brake pin. If so, look at its color, usually blue. This should go up front to where your controller would be under the dash. Next you will need to locate the brake sensor wire, then lastly a hot wire and ground. On my Ford, the brake sensor wire was red but there is really no standard for these wires. The only one I have found to be consistent over the years is the blue wire but with RVs, all bets are off.
Good luck.
Jeff
2005 Newmar Kountry star 3910
Spartan Chassis with ISC Cummins 330 Hp
Big Katuna
Deland, FL
Posted: 05/17/08 07:38am Link  |  Quote  |  Print  |  Notify Moderator
What kind of chassis is it?
Once you can accept the universe as matter expanding into nothing that is something, wearing plaids with stripes comes easy.
debaets
California
Posted: 05/17/08 08:38am Link  |  Quote  |  Print  |  Notify Moderator
We also have a 2004 Dolphin that we bought used. It had a controller installed by the previous owner. It was hard wired into the system, there was no plug specifically for the controller. They also had to run a wire (10 gauge)to the rear of the MH for the plug. Hopefully your controller has installation instructions.
Steve & Jeri De Baets
Manhattan Beach, CA.
2004 Dolphin 5342
79 VW Convertible, Triple Black
 > Brake controller
