RV.Net Open Roads Forum: Tow Vehicles: Dodge 3500 SRW 2WD Auto
Search only in Tow Vehicles
 > Dodge 3500 SRW 2WD Auto
snellville-dave
Snellville, GA
Posted: 05/16/08 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone driving a Dodge 3500 2WD Auto- saw one on cars.com and contacted the dealer for more info (salesman as usual will have to check with svc dept). Asked if the 2005 model had the fuel pump in the tank. I think it does. Does anyone know about the fuel pump location. With diesel at $4.30+ I'm thinking a 2WD might be good enough. Thanks, Dave
SidKaye
Mt Dora Florida, Montreal QC for the Summer
Posted: 05/16/08 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2003 Ram 3500 2WD single rear axle, Auto with the Cummins Diesel. Nearly 90,000 trouble free miles. About 40,000 of that towing a 15,000 lb Excel 5'er.
2WD has certainly been "good enough" for me.
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, Hughes Direcway HN7000S, Satmex5,
http://www.kayepics.com
troll3193
SouthWest, MI USA
Posted: 05/16/08 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
i had a 2004 and now have a 2006. Yes, I believe the lift pump is in the tank...
Big difference between 04, 05 and 06 is subtle difference in behavior of the tranny..
04 has tow/haul mode, but would not go into OD in tow/haul
05 has tow/haul mode, but would go into OD in tow/haul
06 has a tow/haul mode and will go into OD in tow/haul, also has a separate OD off mode. This is also the first model year with support for an exhaust brake with the auto tranny..
My FIL has an 05 2WD dually 3500 and it has been a great truck...
Bryan
2006 RAM 3500 MegaCab w/Cummins Turbo Diesel
Mopar Exhaust Brake
2004 Dutchemen 31BK
djgarcia95928
Northern, Ca. , USA
Posted: 05/16/08 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
My 3500 Dodge 04.5 came with the the fuel pump attached to the side of the engine. Within 20K, the pump went dead. Under warranty , the dealer replaced the fuel pump and put it back into the fuel tank. There was a recall by Chrysler to replace all fuel pumps back into the fuel tank. 60K later, no problems I also had the Dodge dealer install the Pac Exhaust Brake system before I ever drove it off the lot. I would not tow without an exhaust brake.
Dick
djgarcia@earthlink.net
lonestarbike
Big Spring, Texas, USA
Posted: 05/17/08 04:19am Link  |  Quote  |  Print  |  Notify Moderator
My 05 Dodge Cummins has the lift pump in the tank. I believe all 05s came this way. I think was changed to this configuration on 04.5 models.
restlesswind
Fulltime
Posted: 05/17/08 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
My 04.5 had the fuel pump on the engine till 65000 miles,when it quit.Relaced (in the tank) by Dodge on the warrantee was never notified of a recall.
My truck is SRW,3500,LB,pulling about 14000#,30,000+ miles.
There have been a couple of times when 4WD would have been good to have.
BTW I have the 4.10 so the MPG is somewhat lower than some.
Hichhiker DA
04.5 Dodge TD SRW
Fulltimers
camping man
Central Fla.
Posted: 05/17/08 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it's in the tank, but now folks install a draw straw in the tank ,and mount a fass, or other system on the rails. I think the in tank is the way to go though, it's used on most every car out there.
05 Dodge 2500 Quadcab CTD NV5600/3.73rears
97 27ft.Sprinter 5er
Website
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/17/08 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
In-tank fuel pumps are fine... untill you need to replace one! I'd take an external one mounted nearby the tank over an in-tank.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
