RV.Net Open Roads Forum: Truck Campers: Keeping your cool!
 > Keeping your cool!
ShoMe
St. Louis, MO
Posted: 05/16/08 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
I was wondering about keeping the TC cool while running down the road or around town. I don't like the idea of running the generator when moving. It can get pretty hot out west.
Any thoughts or suggestions.
Mooney
Santa Barbara, Ca
Posted: 05/16/08 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
What's the purpose of keeping your camper cool when you're in the truck? I understand that some chose to keep their pets in back and need a living temp. During the winter you need enough heat to keep pipes from freezing. But I just can't understand why someone would go through the effort to keep the camper cold while riding in the truck?
There is nothing short of running you generator that's going to allow you to produce enough power to run your a/c in transit.
'08 Ford F550, Lariat, Link Suspension, Roll-A-Long Conversion, Twin Turbo 6.4, TorkLifts, SuperHitch, "Monster Duty Truckasaurus"
'05 Lance to-the-Max 1181.
Local Music
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 05/16/08 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
Install a MaxxAir and bet a real nice breeze whipping thru your TC! Open a window as far from the fan (mount on a ceiling vent) for the best in flow thru ventilation!
Or go with a 12 volt evaporative coolerTurboKool which works off of your battery and in dryer climates on hot days works great!
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/16/08 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
You can put a boot between the camper and truck, open up both slider windows, and use the truck AC to pre-cool the camper. It's not very efficient, but it's better than nothing. You can pre-heat the camper this way too. The trick is getting the boot to make a descent seal between the back of the cab and the front of the camper.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
Mike and Paula
Palatine IL
Posted: 05/17/08 08:13am Link  |  Quote  |  Print  |  Notify Moderator
I had one (Maxxair)in My 5ther. it was temp controlled and you could control fan speed. loved it. had it in my bedroom in the vent over my bed.
'00 Ford F350 Powerstroke 4x4 DRW
'94 Coachmen Ranger 9.5 SD
Mike - PDM International Truck and Engine
Paula - School Teacher
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/17/08 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Another thought. My old camper originally came with a roof-mounted swamp cooler. Swamp coolers use alot less electricity than an AC unit, as all their running is a blower motor. If a 12v motor is used in the swamp cooler, it can run off the 12v power connection from the truck battery while driving. Should be enough to keep pets reasonably cool as long as the outside humidity isn't high.
mockturtle
Northwest
Posted: 05/17/08 08:41am Link  |  Quote  |  Print  |  Notify Moderator
We don't have a TC but we have a very small TT. We have found that the best way to keep our TT cool while traveling is to close it up tightly and draw the blinds before it starts to heat up. This works amazingly well.
2000 Aerolite 19RB TT
1996 Chevrolet Blazer 6 cyl. 4WD
This car used to be our toad, now is our TV!
cewillis
Tucson, az, usa
Posted: 05/17/08 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Do those TurboKool cooler really work? Looks like a great idea for summers in the southwest.
INSAYN
NW Oregon
Posted: 05/17/08 09:35pm Link  |  Quote  |  Print  |  Notify Moderator
Back in 2006 on our Nebraska, South Dakota, Wyoming, Idaho trip, the outside temps were between 95ºF and 105º the whole time. We just closed all the side windows, installed some Reflectix metalic bubble insulation up against the windows, and closed the blinds to hold them it in place. Then ran the Fantasic on High (rear most part of the camper), and opened the cab access window. It kept the interior of the camper at or below 75ºF-80ºF, roughly 20ºF less than the outside temp. The trick was to block out the sun in the first place, and second.. keep the air moving through and out.
Once parked it took nothing to get down further with the A/C.
1997 F350 CrewCab PSD 4x4, auto.
2005 SnowRiver 8'10", Loaded + EU2000i.
2005 8.5'x16' Interstate West Cargo trailer, Line-X'ed
2005 16' Fish-Rite Rogue welded aluminum boat, 2005 40HP Yamaha 2-stroke O/B.
landyacht318
Near a large body of water
Posted: 05/18/08 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
One reason is the fridge. Think how much harder it has to work in 120 degree ambient temps than in 80.
If it's a poorly ventilated compressor fridge, it could self destruct.
Reflect and ventilate
