gregorya
Torrance, CA, USA
Check out pages 1409-1411 in the McMaster-Carr catalog
I prefer jaw to jaw turnbuckles.
"I have never been lost, but I will admit to being confused for several weeks."
Daniel Boone
2006 Silverado LT 2500HD, 4WD, CC, SB, D/A
2006 Bigfoot 25C9.4
jendiro
Lancaster, CA
Like to thank everybody for their good suggestions. At this point in time I am looking mostly at two items, the HD turnbuckle ( not Chinese) and the chain binder.
I have very little experience with chain binders and really would not know at this point what size I woul need for my job. They cover a lot of territory.
Thanks again you guys and I keep you posted what I will eventually decide on.
And I am alway open minded to more suggestions.
Jerry
2002 Silverado 2500HD
Lance camper 1010
Crumm
Fairbanks Alaska
SoCalDesertRider wrote: Camper tie downs would probably work too, they are basically turnbuckles with some rubber cushion to them.
I use Happijac turnbuckles and they work great. They have a little cushion to them which helps. I contacted Happijac about the capacity and this is what they told me. "The hook straightens at approx. 3000#. The turnbuckle will pull apart at approx. 4500#". I looked at many other turnbuckles like the ones that most guys use and the rating is much less than 3000#. I also have a upper link on my extension which transfers all the tongue weight and rear pulling force to the truck bumper thus reducing the force on the receiver.
96' F350 PSD with smoke added, Airbags, Trailmaster SSV shocks, 315/75R16 Toyo M/T, Centering guides.
06' Adventurer 90FWS with leg extensions
06' Jetcraft XS.
94' Wells Cargo 7'x14'
Slide-Show
silversand
Montreal
Crumm:
Wow! Nice setup
S-
Silver
jendiro
Lancaster, CA
Beautiful job!
Jerry
jendiro
Lancaster, CA
As suggested by SoCalDesertRider I ordered some HD turnbuckles with a breaking strength of 3500 lbs. I installed them this weekend and will give them a try this week.
Thanks a lot for all your good suggestions.
Jerry
smkettner
Southern CA
Here is some real sweet and pretty stuff. Big $$$ but nice. BoSun Supply
silversand
Montreal
Quote: Here is some real sweet and pretty stuff.
Be very careful with those stainless-steel turnbuckles. They will pit and corrode badly (you'll never turn the thread after just a month of winter use), unless absolutely meticulous care is given to them. Additionally, stainless-steel turnbuckles may break under the extreme duty of holding down a TC, they are quite brittle metals.
Good luck,
Silver-
Reddog1
El Dorado, CA (above the fog & below the snow)
I had a similar problem. I simply put a jam nut on the right hand thread side. End of problem.
EDIT: I flat tow with a homemade 50-inch extension.
Wayne
blog.rv.net - Your daily guide to the Open Road.
Reddog1 Photos
96 Dodge (DSL), 2500 (6200#)
88 Bigfoot @ 1500# per decal, Stable Lift (w/remote), 130 watts solar, 100 amp AGM, Polar Cub A/C, EU2000i Honda Gen.
Toad: 91 Zuke
