RV.Net Open Roads Forum: Will old antenna work with the new digital tv boxes?
 > Will old antenna work with the new digital tv boxes?
I_rv2
Illinois
Posted: 05/17/08 09:02am Link  |  Quote  |  Print  |  Notify Moderator
raise the antenna, switch on the booster (as others have said)(if you have a booster), "scan" for channels on the converter box. If none, or just a few, rotate your antenna a little bit (said 25 degrees), scan again ... kinda like fishin' ... you don't know exactly what you are going to get.
Keep rotating the antenna ... and re-scanning. You'll find some stations. I'm sure of it.
mwallenfamily
CA
Posted: 05/17/08 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the info. Our home box works great and we get a lot more stations than with the analog, some we never even got before(not counting the sub channels).
I will try to some of the suggestions, but thanks for all your input.
Reguards
Mwallenfamily
SCVJeff
Santa Clarita, CA.
Posted: 05/17/08 11:43am Link  |  Quote  |  Print  |  Notify Moderator
BTW- The new "term" catching on in the biz for the sub-channels are called "DOTS". Whoda thunk..
Jeff - WA6EQU
I_rv2
Illinois
Posted: 05/17/08 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
>>DOTS
Does DOTS stand for something? Digital Optional Transmission Signals?
Dumb Other Things Station?
Naw, probably not. Just the "dot" ie, 25.2 25 dot 2
Wherever I happen to park
Posted: 05/17/08 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Only if it's a very old RV..
Question.. Describe your install.. I will describe one way Is this how you did it?
(Ant)-----(Box on Wall)----(Converter)----(TV)
Now if you have a box on a shelf with many buttons.. I will suggest a hook up
Page 2: Make sure you have not reversed the IN and OUT connections on the back (Easy to do)
I'm on my 3rd one here.. 1st had a hang up.. Won't know if #3 does for a week (I hooked it up to the test bench earlier today) #2 works great.
I also do no-pass-through work arounds.. If you are near Detroit I can make house calls, or in this case trailer calls.
RCMAN46
NorthWest
Posted: 05/17/08 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have an older FW that I store in my metal shop building. Today I hooked up a RCA converter box I got at Wal Mart. Because of the ceiling height I can not raise the antenna. I opened the garage door and got all but one of the local digital channels. The picture was perfect. In the same situation can not get any of the analog channels.
So I would say YES your old antenna will work with the RCA converter box.
Jim83Itasca
La Quinta Calif
Posted: 05/17/08 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
Hi John
I see a few of the box makers are installing the "Pass through" now and others will no doubt follow also......
The new box coming looks interesting (Apex DT250) but IMHO only time and good reviews will sort this mess out, After checking out the Magnavox at Wally world I'll pass.....By the way I just tested out the fairly new TV (digital) and I'm impressed with the clarity of digital TV with the batwing antenna.....
Jim
RCMAN46
NorthWest
Posted: 05/17/08 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Jim83Itasca wrote:
Hi John
Jim
I think I was misunderstood. In my shop with the antenna down and connected to the analog input of my TV there is not enough signal to pickup the local analog stations. But when I go with the digital box there is a strong enough signal to get all but one station. I was not trying to pass through the digital box. Before I buy another box I am waiting for one that will pass through and hopefully have a HD output.
lap527
Ocala, Florida
Posted: 05/17/08 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
RCMAN46 wrote:
Jim83Itasca wrote:
Hi John
Jim
Remember, the program that is being aired has to be in high def and your tv has to be a high def tv.
2006 Dodge 3500 dually CTD Quad Cab 4X4 / 2006 290EFS Cougar FW
10' Utility Trailer Hauling (2) 2005 Harley Road Glides
Or Gone Fishing - 2002 17' Carolina Skiff 75HP Yamaha 4 Stroke.
Hmm...decisions, decisions. So little time, so much fun!
Just Having Fun!
SCVJeff
Santa Clarita, CA.
Posted: 05/17/08 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
Very good..
