RV.Net Open Roads Forum: Class A Motorhomes: Pictures on the wall
 > Pictures on the wall
bustersbud
Based in Southern Ontario
Posted: 05/17/08 06:51am Link  |  Quote  |  Print  |  Notify Moderator
We just bought a "new" used coach yesterday and will be full timing in it in a couple of months. We've had pictures up on the walls on previous coaches but always took them down when we traveled. What are you using to keep those family pictures etc up while you travel? I don't want to mark up the walls any worse than they are already.
02 38' DutchStar, 02 Explorer Sport Trac 4x4, Remco Disconnect.
Ever Increasing Amounts of Useless Information
RV Questions
AVid
SE Michigan
Posted: 05/17/08 07:07am Link  |  Quote  |  Print  |  Notify Moderator
This is the stuff I use:3M Command Picture Strips. Holds pictures firm so they don't swing around when traveling. Have not had one fail yet.
AVid
springer1
British Columbia Canada
Posted: 05/17/08 07:09am Link  |  Quote  |  Print  |  Notify Moderator
Since we have always kept our Motor Homes for a very long time we nail in a small picture hook and then Velcro a sticky double sided piece to the picture and the wall. Yes it does leave a little hole in the wall. But it is small enough to easily go unnoticed. Hope this helps. Oh yeas over 1000's on miles one has never fallen off the wall.
John M
Grayslake, Illlinois
Posted: 05/17/08 08:02am Link  |  Quote  |  Print  |  Notify Moderator
We also use the 3M Command strips. For pictures we use the regular strips, but for the clock I used the "Velcro"-like Command strips so that it could be removed to change batteries. All have worked very well for us except for the Command strip hook my wife used to hold up a magazine rack. Pulled off in a couple of days, but didn't do any damage.
John and Susan
2005 Itasca Meridian
Jeep Wrangler Toad
thecaptain
Belleville,Mi.48111 USA
Posted: 05/17/08 08:22am Link  |  Quote  |  Print  |  Notify Moderator
They make stuff called poster putty it will hold light pictures to the walls , you can use 3m picture hagers with it .
Ken/Ellen(RET)
2000 F250 Superduty
7.3psd/Banksbrake/Smartlock/Trans command/3.73gear/Edge EZ module
2002/29ft-Terry 5er:
Take life one day at a time.
hitchup
Fulltiming in Madison, VA
Posted: 05/17/08 08:46am Link  |  Quote  |  Print  |  Notify Moderator
We've seen a combination of things. Our last 5er had pictures screwed into the wall. But we find as long as the picture frame, plate or clock isn't too heavy, that the Heavy Duty Velcro works the best.
2009 DRV Mobile Suite 38TKSB3....our custom home
2008 Ford F450 Lariat CC 4x4......his office
Working Fulltimers since 3/2005
"Shoot for the Moon! Even if you miss it, you will land among the Stars."
MeanderMan
Fulltiming Somewhere
Posted: 05/17/08 09:40am Link  |  Quote  |  Print  |  Notify Moderator
I agree with other posters; the 3M Command Strips work well and can be removed without any damage to the wall. For our one large painting, I stapled heavy-duty velcro to the wall and picture, but it's in an area where a picture will always be hung.
Happily Fulltiming Somewhere
2006 Itasca Ellipse 40FD
Our RV Blog
Maanpa
Central Point, Oregon
Posted: 05/17/08 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Go to a mirror store, they have a special metal strips (one for the wall and one for what your hanging. We also use Velcro on bottom of the item to keep from swing out. We never take down our picture or mirrors. The heaviest mirror is around 50 pounds. We purchased ours on line, if I can find the information them I will PM it to you.
Koran & Darlene
Creole, Cajun & Bayou(Our 4 Legged Kids)
2007 Itasca Suncruise 38T
PressurePro/Progressive SP
Steer Safe/Vantage BB/Stowmaster
Hughes Autoformer
2004 Rubicon
Goodsam/PA/F394282
brinasmemaw
southern Oklahoma
Posted: 05/17/08 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
I have used 3M Command interlocking fastener strips on all of my pictures & even a heavier clock, they hold very well. Haven't had anything fall off the wall in miles of traveling, including the Alaska Highway! Becky
RayChez
Barstow, Ca. USA
Posted: 05/17/08 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
We use poster putty. You can buy it at Wal Mart and it works really good. You sure don't to use any screws or nails.
