RV.Net Open Roads Forum: Fifth-Wheels: Jayco Designer "Legacy" owners
 > Jayco Designer "Legacy" owners
Hoops
Indiana
Posted: 05/18/08 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
We have not had any problems with cracks in the bedroom slide. We have one 15000 BTU air and we don't find it necessary to have a second AC. The only time we have a problem in cooling it down is after traveling all day and that really isn't a problem because we run a small fan in the bedroom and in 20 minutes the whole unit is cool. They fazed out the Legacy series a year after we got ours and added the extras as options to the Designer. Guess customers are asking for the Legacy or they wouldn't be bringing it back. Oh and on the AC thing, we have been in temps as high as 106 and no problems.
Hoops
The Hoops. ED and Becky
Missy our little Bichon
2004 F350 V10
2005 Jayco Legacy 38RDQS
TandA-n-Mac
new jersey
Posted: 05/19/08 08:24am Link  |  Quote  |  Print  |  Notify Moderator
hoops,I would agree with one ac(very comfortable). What I don't understand are rigs that are mounting ac towards rear of unit. Common sense says air would be not so cool by the time it gets to the front. What does RDQS mean, rear dining quad slide? To Chevy man,
My unit is a 04 3780RLQS,only fiberglass was repaired. I would think my warrenty is up, it really is just a small eye sore. Yes,the Legacy is a $6-10,000 upgrade Designer. my unit came with $3,000 exterior decal upgrade.Can post interior pictures if requested(upon DW's approval of coures).ha ha. specs can still be found on Jayco site.
06 F250 6.0 TD,SC,SB,4x4,Towboss,3.73 rear.Firestone air bags,285/70 R17 3795lb tires,18000 slider; 04 38' Jayo Designer "Legacy" 5er; all I need now is satilite TV and hit the lottery; NAVY,"WE'LL NEVER FORGET,land of the free because of the brave"
USA in a Chevrolet
Manahawkin, New Jersey
Posted: 05/19/08 09:13am Link  |  Quote  |  Print  |  Notify Moderator
I believe that Jayco has a 5 year warranty on the frame. I would definitely talk to Whitehorse about it. The fiberglass is just a symptom of the problem you might have underneath. Do a search for frame repairs on Jaycos, Montanas, etc.
lemonjim1
Oquawka, Il 61469
Posted: 05/19/08 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2004 Legacy, full body paint etc. We had the crack at the lower left corner. When we took it to the JAYCO factory they told us that there was a "silent recall". The slide had to be removed and additional strength incorporated. If you are out of warranty you may be out of luck. But, I hope not.
Hoops
Indiana
Posted: 05/21/08 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
RDQS stands for rear den quad slides. We have the living room that has doors you can shut off that room. I believe Jayco had a 10 year warranty on the frame. So check it out. If it was a silent recall, then Jayco would hornor it.
Hoops
Scuba Chop
Fredericksburg, VA
Posted: 05/30/08 09:22am Link  |  Quote  |  Print  |  Notify Moderator
We have a 2003 Designer Legacy 3710, and had the slide out crack. As mentioned, the only repair is take it down to the frame, weld aluminum support, and rebuild the side wall. In fact we had it done twice, once at "authorized" Jayco dealer in Baltimore, (no longer authorized due to the lousy job/service (40 hr job took 4 months)) and then at Jayco when the first repair failed. Supposedly the defect only effected Designer Legacy line.
Jayco not only covered both repairs, but also fixed a few other things because of the hassle of having to do it twice, even although our unit was out of warranty.
Jayco 3710
2004.5 Dodge Cummins, DRW, 4x4, 4.10, Auto, Quad Cab
Prodigy Brake Controller
Husky 16K hitch with UBS
RV Forum and Good Sam Club Stickers
"Slow, Grandparents at Play" caution sign on ladder
loydt
Concord, NC, USA
Posted: 05/30/08 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Jayco will make this repair for you free of charge, no matter how old it is.
2007 Dodge 3500 Quad Cab DRW, 5.9 Cummins, 6 speed, 4x4, Jake Brake
2008 Jayco Designer 35 RLTS
2008 Discovery 40X DP
My Pictures
Midwest
Carbondale, IL
Posted: 05/30/08 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
The Designer Legacy name was phased out in 2003. In 2004 the top end was just called Legacy. The Legacy had as standard all the top end options of the Designer Legacy. I have a 2004 Legacy. In 2004 the basic Designer was down graded. In 2005 the Legacy was gone and the down graded Designer became the top of the line.
I consider the whole series of events as a marketing effort to lower the Designer in the overall industry pecking order to a lower cost 5th wheel.
I don't remember the exact year, but this is when the got in and out of the Class A business. This was not a successful venture for Jayco.
IMHO Jayco as a company made a decision to pursue the entry level market with their highly successful Jay Flights and Jay Feathers.
The purchase of the Travel Supreme facilities is a decision to re-enter the high end market. This also provides the opportunity to pursue the class A market again.
3710RLTS 2004 Jayco Legacy
2007 3500 GMC SLE CC LB D/A Dually 2WD
