RV.Net Open Roads Forum: Travel Trailers: help with water pump
 > help with water pump
JCR-1
Crystal River, Florida
Posted: 05/17/08 11:28am Link  |  Quote  |  Print  |  Notify Moderator
I have a small 18 foot trailer equipped with a shur flo 12 v water pump. Vibrates like crazy (noisy) and their is no presuure to the lavatory sink. Seems like it may be air bound , but how to you expel the air. running doesn't seem to help it. Appreciate any comments. Thanks
emaav
Hillsboro, Oregon
Posted: 05/17/08 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
Open a faucet, that should help clear the air in the line.
Me (Eli) 1972
DW (Monique) 1974
DS (Alex) 1996
DD (Amanda) 2002
1997 GMC Safari
2003 Jayco Kiwi 21C
handye9
Park City, IL 60085
Sounds more like you have a clogged filter in the line to lav faucet or, the screen on the end of the faucet is clogged.
06 Titan Kingcab
06 Flagstaff 831QBSS
Wife and I
Buddy the Beagle
USN MCPO (E9) Retired (active duty 1973 - 1995)
Check out my mods
enblethen
Moses Lake, WA USA
Posted: 05/17/08 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Remove the connection from the output of the pump to insure you are getting water through the pump.
Verify by removing intake that water is getting to the pump.
Bud
Suzuki XL7 pushing Pace Arrow
CampSight
Posted: 05/17/08 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
I had an issue with insufficient pressure at the bathroom faucet only. All others were fine. Turned out there was an obstruction in the lines leading to the faucet; some debris got in during manufacturing. Was repaired under warranty.
dave54
CA.
Posted: 05/17/08 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
As for the vibration and noise, that fix is cheap, although may not be all that easy. Get on your hands and knees, or your belly, and trace out every water line from the pump to every faucet. You may have to empty some cabinets to see the lines, or open the access panels.
Every time a line goes through a wall, or alongside a wall, insert some foam pipe insulation. Padding between the water line and any surface.
Log off and go camping!
choffman41
Mokelumne Hill, CA
Posted: 05/17/08 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
On my vintage Open Road, every time I completely drain the system I get an air lock at startup time. What I do is take the shower nozzle off and apply a little suction on the hose. Pretty quick, the water is flowing nicely. How you apply the suction is up to you.......( maybe tell the kids it's a new game).
Dick_B
Palos Heights, IL USA
Posted: 05/17/08 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Just for grins you might also try opening ALL of the cold water faucets to see if that clears the air lock or whatever it is.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
