RV.Net Open Roads Forum: Tech Issues: AC will not work with generator
 > AC will not work with generator
Cla
Virginia
Posted: 05/17/08 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
The AC unit will not work with the generator, as a matter of fact the microwave does not work either.
I have an Onan generator that wan't used for about two years. It was checked and the papers say AUX GENERATOR RUN TEST VOLTZ 127 HERTZ 59 . Any ideas? thanks.
trnfla
Tampa
Posted: 05/17/08 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
check the main breaker on the generator.
Have a great time camping,
Terry
Please say a Prayer for my 10 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
trnfla
Tampa
Posted: 05/17/08 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
also, on my unit I have to plug my power cord into the generator outlet located inside the storage cabinet that my power cord goes into.
Cla
Virginia
Posted: 05/17/08 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
I am new to this...what does the main breaker look like and where could it be ? Thanks....
Gale Hawkins
Murray, KY
Posted: 05/17/08 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
What year, make and model do you have? How many A/C's do you have?
Adam-12
Northern CA
Posted: 05/17/08 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
I think it might be helpful if you ask a neighbor or someone in your family/friends that also owns an RV to actually show you these things. It's easier for someone to show you where your breaker box is and what to look for instead of reading it on this forum.
2008 Silverado 2500HD Duramax/Allison DIESEL/4x4/CC/Z71
2008 33ft. TT/BH-Super Slider
Parallel Honda EU2000i's
Yaesu 857d
Dipoles/random wire/tuners
Fishing equip.
Quads
Life member: NRA
ALCOHOL
TOBACCO
FIREARMS!
salem
Central Valley, Ca
Posted: 05/17/08 11:23pm Link  |  Quote  |  Print  |  Notify Moderator
My fuse box is down under the over. Just open the little flap.
miket
Southwick, Ma
Posted: 05/18/08 05:00am Link  |  Quote  |  Print  |  Notify Moderator
Locate the generator, some place on it should be two circuit breakers, both should be on. If the are on and you still have no power, your transfer switch may be bad. The location of the transfer switch varies from coach to coach. It is also possible that the gen set is shot if it sat idle for two years. They should be run under load monthly.
Mike T
2005 Winnebago Voyage 33V, Workhorse W20, with '06 CR-V in tow, SMI 4 wire Braking system, Blue Ox Underskirt, Pressure Pro.
Southwind85
Where I Park
Posted: 05/18/08 08:48am Link  |  Quote  |  Print  |  Notify Moderator
I'd bet the 120VAC sockets are inop as well as the fridge not operating on 120VAC.
First thing, and most likely cause, is to check to make sure the power cord is plugged into the generator plug in the cable storage box.
Then if necessary, check circuit breakers.
The Good Life
Hurricaner
Hurricane Utah
Posted: 05/18/08 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Year, make and model of RV might help. Also post the complete model #of gen.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
