RV.Net Open Roads Forum: Tow Vehicles: the 6.7 CTD saga
Search only in Tow Vehicles
 > the 6.7 CTD saga
houhjc
at the pump, tx
Posted: 05/18/08 06:50am Link  |  Quote  |  Print  |  Notify Moderator
We have two new 6.7 CTDs. One in a 3/4 ton, automatic, and one in a 1 ton DRW with a stick. With about 4000 miles on the 3/4 ton, the check engine light came on. Taking it to the dealer, they say all kinds of stuff. It appears that the turbo is dirty, and the sensors are in need of cleaning. Whatever it may be, they kept the truck for 3 days, and said it was ready. They cleaned what ever was dirty. After leaving the dealership, about a mile later, the light came on again. Took it back, they did some magic stuff, and the light is off again.
Last night, in the 1 ton, the light came on. There are 4500 miles on the truck. I see 30 pounds of boost on my gauge, so im not gonna buy that the turbo is not allowing enough boost as they said in the other one. They replaced the turbo completely in the 3/4 ton.
Anyone have a horror story that goes along with this? It seems the repair center is lined up with 6.7's to work on.
2007 Ram 3500 6.7 DRW 4X4 6speed manual
2003 362bbs bunk house
wayne_tw
South Dakota/Georgia
Posted: 05/18/08 07:09am Link  |  Quote  |  Print  |  Notify Moderator
Your dealer is inept. There is a technical service bulletin that will solve the check engine light coming on. It is a simple "reflash" of the computer loading new software. They may have cleaned a oxygen sensor module, but that is just a very temporary fix as you have found out.
RRUGG
Newaygo, MI,USA
Posted: 05/18/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
We had the check engine light come on but it went out by itself in a couple of days. Has not come back on. Earlier this month our AC quit putting out cood air. Dealer found a loose connection. Less than a month after we got it last October there was a recall that consisted of a reflash for something. Had it done. I loved our 2001 Dodge CTD, kept it longer and put more miles on it than any other vehicle I've owned over the last 50 years and I like the 6.7L even more than the '01. Better in every way except unloaded highway mpg. Towing mileage is the same as the '01 but it does the job easier.
RRUGG
2008 Dodge 2500 QC 4x4 SB Cummins 6 speed auto 3.73
1997 Holiday Rambler 29FK travel trailer
2006 Summit 22RB travel trailer
2003 Dodge Grand Caravan Sport
Bob & Grace professional retirees
Good Sam life members
Camped in 49 states. Missing Hawaii.
camping man
Central Fla.
Posted: 05/18/08 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Common among 6.7s, check the diesel forums, some are trading in for the older 5.9s.. The only folks that are having any luck are hot shotters, they work the heck out of them, their not for city driving for sure.
05 Dodge 2500 Quadcab CTD NV5600/3.73rears
97 27ft.Sprinter 5er
Website
ba8w7
Media Pa
Posted: 05/18/08 11:09am Link  |  Quote  |  Print  |  Notify Moderator
Had the same problems with mine,Engine light,on,off,on,off.
A friend of mine is the tech who works on my truck at my local dealer and he told to me to use the engine brake,supposedly this heats everything up and cleans any soot off of all the sensores that are jammed into this truck.
Seems to have worked so far,I did have to replace the pcv bypass with 8500 miles on the truck. Everthing seems good now.
Mike
Pam
Brian
Zoe (the crazy blacklab puppy)
07 Ram 2500 Cummings Sport
07 Cougar 301BHS
matthewc66
San Diego
Posted: 05/18/08 11:29am Link  |  Quote  |  Print  |  Notify Moderator
07 6.7 DRW auto.
No problems, pulls like a locomotive.
Mileage is so so but otherwise a great truck.
houhjc
at the pump, tx
Posted: 05/18/08 11:30am Link  |  Quote  |  Print  |  Notify Moderator
everytime the truck is running, the engine brake is on. anyone heard how to get the codes to come up by turning the key off and on several times?
jjfay03
Washington State
Posted: 05/18/08 11:39am Link  |  Quote  |  Print  |  Notify Moderator
I was told to turn the key off and on (not starting the rig) 3 times and the code would be displayed.
John and Jeannine + 3 Boys 9, 6, and 4.
2007 Dodge 2500, 5.9 CTD LB, Husky Brake Controller,
Husky 20K Hitch, Linex, and Firestone Airbags, Pac Brake.
2007 Keystone Challenger 34' SBH 5er
I can't forget the puppy, Little Boy!
wayne_tw
Posted: 05/18/08 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have great service out of my 6.7 and I am anything but a "hot shotter". Guess if you could buy a new truck you would be happy with it, but since you can't, you bad mouth the new ones.
SoCalDesertRider
SanDiego, CA, USA
Posted: 05/18/08 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
Play nice, boys...
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
 > the 6.7 CTD saga
