N9MB
Indiana
Work great!
Bagger97
Littleton, Co
Do NOT install the convertor between the antenna and the switch box or you will fry the convertor. There is 12V going up to the antenna amplifier on the cable.
Alan & Patty
Munchkin & Maddison
2006 Itasca Sunova 29R SE
We'd rather motorize our winterhome than winterize our motorhome.
jmaotto
Rockwall, Tx
Does you unit have analog pass thru? I am have a difficult time finding one that does.
SCVJeff
Santa Clarita, CA.
jmaotto wrote: Does you unit have analog pass thru? I am have a difficult time finding one that does. There are several on the way, but I haven't seen a coupon box with 'bypass" on the shelves yet. Anyone else?
Jeff - WA6EQU
ADAD437
New Albany,Ind. USA
YEP. Just got two philco's from BSAT.They have pass thru. First one's i have found. Have not tried them yet.They are on the list for coupons. Cost me 11.99 each.
James (Naomi and Tut the Mutt, Both deceased and missed)
2005 georgie boy Pursuit
ringhand
Minnesota
ADAD437 wrote: YEP. Just got two philco's from BSAT.They have pass thru. First one's i have found. Have not tried them yet.They are on the list for coupons. Cost me 11.99 each.
Is philco a brand? And what is BSAT?
2007 Jayco Jay Feather 29A
2003 Ford Expedition Eddie Bauer (5.4L w/ Tow Pkg)
ADAD437
New Albany,Ind. USA
ringhand wrote: ADAD437 wrote: YEP. Just got two philco's from BSAT.They have pass thru. First one's i have found. Have not tried them yet.They are on the list for coupons. Cost me 11.99 each.
YES PHILCO is a very old brand. BSAT.NEThere it is is a web company on the list of approved vendors on the govt. site.
deandec
El Dorado Hills, CA
What is the benefit of having Analog Pass Thru?
Dean
95 CC Magna Jeep GC
(Vietnam Vets may be eligible for medical care and disability compensation. Contact the VA if you have prostate cancer or type 2 diabetes.)
SCVJeff
Santa Clarita, CA.
deandec wrote: What is the benefit of having Analog Pass Thru? Because even after the analog cut-off date there will still be active analog translators and LP transmitters out there, including SAC. If you don't have a device with pass-thru, you will need to split the antenna to feed the converter and the TV through a A-B switch, and use the switch to switch between antenna direct, or the converter.
WITH Pass-thru, you turn the converter off and it bypasses itself.
hilldude
Red house WV
jmaotto wrote: Does you unit have analog pass thru? I am have a difficult time finding one that does. RCA and some others listed on gov web site
