RV.Net Open Roads Forum: General RVing Issues: Smelly fridge
 > Smelly fridge
tnman
TN
Posted: 05/18/08 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
We recently bought a 90 model TT and the fridge smells awful. It reminds us of a dead mouse smell! We've washed it down several times with bleach and water, greased lightning and used odoban(sp). We've left the door open for weeks and within a few hours of closing it the smells back. It does matter if it's turned on or not.
The only place you can smell it is in the fridge compartment, the freezer seems fine. You can't smell it outside at the access door to the fridge, you can't smell it under the fridge as this is where the hotwater heater and furnace are located and you can open that area up. It's just in the fridge.
Any suggestions???
Thanks,
Randy
exfuzz02
Lakewood, WA
Posted: 05/18/08 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Try a couple of boxes of Arm & Hammer baking soda..(open them) Might do the trick...?
2007 Jayco 33DS, Greyhawk/Kodiak Chassis,Chev V-8
Toad: 2004 Jeep Liberty 4x4.
DutchmenSport
Indiana
does it smell only when the frig is turned off and the door closed. or does it also smell when the fridge is running, cold, and the door closed? or all the time, door open or closed, on or off?
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
ikejan
FL.
Posted: 05/18/08 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Coffee filter with about 3 table spoons of coffee.It help us get rid of smell from hamburg in freezer after losing power.The door close while park for awhile seemed to take care of it.Good luck
Musicman
Wenatchee, WA
Posted: 05/18/08 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Another odor absorbing trick is to fill the compartment with crumpled newsprint. Close the door and leave it for several days. The paper will absorb the odor, and can be discarded and replaced several times, at virtually no cost.
I used this trick to "clean" a freezer of fish odor on a boat.
Musicman
FMCA #F333309
'97 Winnebago Vectra
'01 Blazer LT
wny_pat
Western NYS
Posted: 05/19/08 12:14am Link  |  Quote  |  Print  |  Notify Moderator
Grind up three charcoal briquets and put them in a bowl in the frig. Close the door for a couple days. Open and remove the charcoal. If smell is still in frig, repeat. You can also use a pet odor remover called "Nilodor". It is excellent. Find at a pet store
Oh, wash inside of frig with water, dish soap, and baking soda ONLY! Nothing else, that should be in your frig manual. That plastic inside the frig will absorb orders from cleaning products.
tnman
TN
Posted: 05/19/08 06:08am Link  |  Quote  |  Print  |  Notify Moderator
The smell is actually in the freezer compartment as well. With the doors open for a few days there is no smell at all, but close them for a few hours and it's there. Doesn't seem to matter if the fridge is on or off.
We washed it down with baking soda and water last night and poured out two boxes of baking soda in the freezer and fridge. If this doesn't work I'll try some our your suggestions. Please keep them coming because it's really really bad.
Thanks
HarleyMedic
Sour Lake, Texas
Posted: 05/19/08 06:22am Link  |  Quote  |  Print  |  Notify Moderator
I 2nd the charcoal.
Big Sexy and BonBon
2003 Dodge 2500 4x4 Laramie Cummins Auto, Edge EZ, AEM Brute Force, Timbrens, B&W.
2004 35SRV Victory Lane
1998 Harley Road King (Mine)
2003 Harley Road KIng (Hers)
2004 Yamaha Grizzly LE
JustLabs
Washington State
Posted: 05/19/08 08:55am Link  |  Quote  |  Print  |  Notify Moderator
I haven't tried it on a refridgerator,but when a cooler gets something nasty left in it,I wipe it down with Vanilla extract.
The Vanilla extract tip was actually in the literature that came with one of my coolers. It works well.
2007 Dodge Ram 3500 SRW,4x4,Cummins 5.9, 6spd.
2007 Keystone Cougar 289BHS Fifth Wheel.
tnman
TN
Posted: 05/19/08 11:56am Link  |  Quote  |  Print  |  Notify Moderator
I've researched on the internet and found several reports of some fridges smelling like ammonia because of an evaporator leak. I don't really think that is what ours smells like but might be. Would you be able to smell the ammonia even with the fridge turned off? We cleaned it out and left the doors opened for days and could not smell anything, but within hours of closing the doors you could smell it when you opened it back up and we didn't even have it turned on..
 > Smelly fridge
