RV.Net Open Roads Forum: Dinghy Towing: Running Wire Thru Firewall 2008 CRV
Search only in Dinghy Towing
 > Running Wire Thru Firewall 2008 CRV
UncleFudd
Hobe Sound, Florida
Posted: 05/18/08 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
The Brake Buddy we will use in our 2008 Honda CRV requires a small cable that attaches between BB and the Break-Away switch. It is necessary to run the cable thru the fire wall to make this connection. We would prefer not drilling a hole. Anyone found a way to squeeze a small cable thru the fire wall without drilling?
Sure appreciate any tips or help on this one, they sure make the '08 tighter than our previous '04 CRV.
Thanks,
Jim
Musicman
Wenatchee, WA
Posted: 05/18/08 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have a CRV, but I didn't run the wire through the firewall of the Blazer. I removed the finishing panel under the driver's side door, and drilled down through the rocker panel. I knew there was nothing there to be destroyed.
The wire enters the cabin from under the reinstalled finishing panel and the extra wire is coiled under the drivers seat, when not plugged in to the BB.
Just another option. Good luck with the installation.
Musicman
FMCA #F333309
'97 Winnebago Vectra
'01 Blazer LT
Bumpyroad
Virginia
Posted: 05/19/08 04:28am Link  |  Quote  |  Print  |  Notify Moderator
I have never been able to find a good way to do this on any toad. I just run a wire out from the back of the hood, around the pillar and into the door.
bumpy
K3BH
Slower Lower Delaware
Posted: 05/19/08 07:44am Link  |  Quote  |  Print  |  Notify Moderator
Whenever I need to pass a cable between the engine compartment and the inside of the vehicle, I use an existing large grommet by punching a hole in the "web" of the grommet and pushing the wire through. Sometimes a dollop of sealant completes the project, but usually the hole self-seals nicely around the wire.
This is how I got the cable through for my setup on a 2005 CR-V. Grommet is on the driver's side, above where the clutch pedal would be.
Jay
Jay, Susan, 2 cats in Bigfoot 29G 6.0L Diesel. Toad Honda CR-V
Larry Cohen
Mobile, AL
Posted: 05/19/08 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
I'm with K3bh....I think ALL cars must have at least one grommet in the firewall to run their stuff to and fro the engine compartment....worked for me on 2 Saturns
2006 Mountain Aire 43
Wife, K9 Maggie and 4 sugar gliders are co-pilots, along with Garmin Nuvi 660
06 Vue AWD toad with Brakemaster
Blue Ox Adventa II towbar
Diplomat Don
Moorpark, Ca
Posted: 05/20/08 12:12am Link  |  Quote  |  Print  |  Notify Moderator
Same here with the grommet....often a parking brake cable will have one...
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2007 Dodge Dakota 4WD
Bumpyroad
Virginia
Posted: 05/20/08 04:51am Link  |  Quote  |  Print  |  Notify Moderator
someone posted exactly where the grommet was on my 2005 saturn and it was buried so far down and behind "stuff" I couldn't even get at it. Perhaps if I was 18 years old and 121 lbs. I could have done it.
bumpy
knobhill24
Upper Michigan
Posted: 05/20/08 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2007 CRV which should be the same there is a rubber plug in the middle of the firewall comes out behind the console. Worked great for my Brake Buddy.
Jerry 06 Cambria 07 CRV
Silverbarr
St. George, Utah
Posted: 05/22/08 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
I ran my Brake Buddy wire thru the firewall on my '08 CRV. I examined the firewall looking for existing "chassis plugs" and could not locate ANY. I uncovered the interior carpeting and the felt underlayment (this underlayment is glued to the sheet metal)on the passenger side and then drilled a 1/4" access hole. The location I selected is on the passenger side. As you look at that side you can see 4 black steel brake lines running horizontally. Three and one-half inches below those lines runs another horizontal pipe or conduit. The access hole is 3" below those lines and about 2" to the left as you view it from the engine compartment. There is also an AC drain hose just below and to the right of the new access hole. Another reference is noted where the firewall angles back at a 45 angle. I drilled the hole from the passenger compartment toward the engine compartment. I ran the wire and then sealed the hole with silicone sealant. On the interior I ran the wire in back of the center console and then under the carpet to a location close to where the brake controller sits. If you need a picture just contact me. Sorry about the long winded explanation.
