chuck4788
West of the Middle
The freeze and skip sounds like a weak signal. Is the dish aimed properly or was it raining?
I've run DirectTV sat receivers powered by a Heart 2500 MSW with no problms.
Chuck
02 Beaver
505hp C12 Cat
Trailblazer toad
Herewego
Dave, driver of the Winnebago, likes to travel.
Works fine on shore power. Unplug shore power and it freezes and skips. Plug shore power back in, and it's fine. I'm perplexed.
2004 Coachmen Aurora on a FORD V-10 Chassis
2004 Jeep Liberty
Don't take your organs to Heaven. Heaven knows we need them here! Dave has a dog named Muffy and Mike owns a Cockapoo!
Our Pix
Herewego
So...Update...
It is only skipping/freezing on a couple of channels. I get Speed, Fox, ESPN, and NBC and their "sister" stations, so I'm good.
2oldman
WA
You take your chances with msw. Sounds like that's the problem.
was_butnotnow
Fulltime: Emery, SD
I have Xantrex 2000 watt unit MSW and it works great with all my electronic itmes. DirecTV R15 DVR. Now I have since changed my R15 unit to run off a cheap 140 watt Radio Shack inveter so I can leave it on while boondocking so it will record and stay on track with the channel updates. NEVER have I had a problem. MSW only slows down motors as in our microwave.
See where we are at: DataStormUsers map
Sharing Travel Journals and Adventures Hitchitch.com
Personal site Fulltime.Hitchitch.com
was_butnotnow
Fulltime: Emery, SD
Herewego wrote: So...Update...
New issue here.. sounds like you have a loose or bad coax cable. That will cause the type of problems you are having. Connect a new cable from the dish to the receiver unit and see it that does the trick. Sounds strange but that was the kind I problem I had once when I could get only some satellite channels.
Bob Landry
Austin, texas
We just had a thread relative to this particular inverter. Make sure the neutral wire on the inverter output goes directly to the neutral wire of the plug or device that it's feeding and that it's not connected to the common neutral buss.
