RV.Net Open Roads Forum: Class A Motorhomes: A/C life span ?
 > A/C life span ?
mike4947
N. Syracuse, NY
Posted: 05/19/08 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
Just as an FYI: roof top units don't operate quite the way the engine mounted/dash AC's do. While you can "freeze" your hand over one of a car/truck vents; the roof top unit is designed that it's output temperature is 17-20 degrees lower than the input temp.
So simply check the temp difference while you're up there cleaning the unit out.
This is because there's no outside hot air exchange that a dash unit could have. As the RV cools down the inlet temp also gets colder so you don't have to be afraid the AC will only drop 20 degrees from the outside temp.
As for life span, IIRC from the manufacturer's notes has a mean time between failures of 12 and 15 years. Proper maintenance/cleaning/ and storage raises it. We have units from the early 80's that are still running like clockwork, but we also have morons that ignore the units, let them clog up, etc and replace them every couple of years.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
Want to sell some of your gear? -
Free Classified Listings on RV.Net
They say you learn by your mistakes, in that case I must be a genius.
Gale Hawkins
Murray, KY
Posted: 05/19/08 10:33pm Link  |  Quote  |  Print  |  Notify Moderator
It is easier to get tired of them than wear on out. I have thought of replacing the gasket seals on our 1993 and swap front to rear since I think it has never been used. The filter looked new and was clean unlike the front one. The one in the bed room is too cool for sleeping. Just to same the front one in hot weather sometimes I just run dash and rear unit. We can only run one or the other at 30 Amps.
pbe10
Tonawanda, NY
Posted: 05/20/08 05:44am Link  |  Quote  |  Print  |  Notify Moderator
My 30 year old units continue to run fine. Just keep the filters clean.
replaced the roof gaskets a few years ago.
tom_kat
way upstate new york/lake george area
Posted: 05/20/08 07:18am Link  |  Quote  |  Print  |  Notify Moderator
the ones on my 85 are origanal still work great one will keep the whole rv cold with outside temps in the high 90s.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
 > A/C life span ?
