RV.Net Open Roads Forum: General RVing Issues: Getting rig out of yard
 > Getting rig out of yard
smkettner
Posted: 05/20/08 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Plywood is the way to go IMO.
lynndiwagon
Yukon, Oklahoma, USA
Posted: 05/20/08 09:13am Link  |  Quote  |  Print  |  Notify Moderator
The final straw was when I was pulling the rig through the gate into the back yard I got stuck with the rig halfway through. I was in a real pickle, unhooked the truck but couldn't get it out of the back yard because rig was halfway through gate. What a muddy mess. Had to wait a week for the ground to dry up, then re-hooked and finally got it into yard. Left huge ruts, and when backing around rig wheels tore up the yard. As I stated, I moved it next to the house. Worth every penny.....Crushed gravel would have probably worked instead of the concrete. You might consider a driveway from the street to the backyard?
Lynn & Diana Wagoner
One Shih Tszu
Two Boston Terriers
2005 Chevy 2500HD D/A
2006 HHII 29.5LKTG
Retired Gov't employee
martinar
Cincinnati, OH
Posted: 05/20/08 09:48am Link  |  Quote  |  Print  |  Notify Moderator
I camp in fields all the time anyways. Put it in 4 and go. Unless its a swamp, you'll be fine as long as you don't stop to look around.
BobsYourUncle
Surrey, BC Canada
Posted: 05/20/08 10:47am Link  |  Quote  |  Print  |  Notify Moderator
I have done this many times over the years with various types of trailers, both for construction and pleasure trailers.
All I ever do is put down some minimum 5/8" plywood and then put 2 X 12's on top of the plywood to run the wheels on. It requires a fair bit of lumber, but is well worth it to avoid tearing up somebodies lawn. (Or my own)
It takes a little time because you have to move a few feet, get out and move the wood, check to make sure you are on the 2X12's, but it works good.
Just make sure the wood is under the TV too.
Duramax / Allison
Fire Red
95 Sportsmen 25.5' TT
81 Citation 25' "Tail dragger" "Under construction"
"Workin' man's rig"
Check Out My Rebuild Project (Updated June 15, 2006)
Project Feedback
BarneyS
S.E. Lower Michigan
Posted: 05/20/08 11:44am Link  |  Quote  |  Print  |  Notify Moderator
For a permanent solution click here.
Barney
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the new RV.net Blogs!
Visit our website here
kkmack
San Antonio, Texas
Posted: 05/20/08 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
How about cardboard? You can get boxes for free or almost free from grocery stores. As a kid, we'd sometimes get stuck when we would go driving on the north end of South Padre Island. To get back to hard sand, we would lay out a trail of flattened boxes. Worked like a charm.
Kerri
2007 Aerolite 23BH
2000 Suburban
cwhtrains
Carmel, IN
Posted: 05/20/08 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
Call a tree moving company and they will have plenty of plywood sheets that they use to move their tree planting trucks (tree-spades)across lawns, if it is just a one time thing. Other wise try some two by 12's and use a helper to keep tires on the wood.
Clayton Herbert
2006 Winnebago journey 36G
Cat 350
tom_kat
way upstate new york/lake george area
Posted: 05/20/08 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
i would use planking just get some rought cut 2x12 befor they plane them down ,get some from a lumber mill if theres one around cheaper then finished and thicker and wider,plywood could get expensive buying the thick stuff planking should be stronger ,
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
pammi
Westland, MI
Posted: 05/20/08 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
I like Barney's permanent solution. Be careful with the wood, make sure they're long enough. I put one under my HTT in the side yard when I parked it. When I pulled it the camper out of it's spot and it came off the wood, the wood angled up and snagged the waste valve and busted it off.
2004 Rockwood Roo 23B (new to us)
2006 Nissan Xterra
When we camp, it's DH & me mostly. Occasionally step-daughter (16) comes, though not necessarily her choice
Chuck&Gail
In the Colorado Mountains
Posted: 05/20/08 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
Heres an old truckers trick, if it isn't a swamp. Get a roll of heavy duty chain link and put it over grass, then drive on chain link. Once out, roll back up and store for next time.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
