RV.Net Open Roads Forum: Fifth-Wheels: Dometic Refrigerator keeps freezing!
 > Dometic Refrigerator keeps freezing!
Seiara
New Jersey
Posted: 05/20/08 09:02am Link  |  Print  |  Notify Moderator
Dometic refrigerator keeps freezing! I have model RM2652. Was told try replacing the thermister. They make a replacment Kit called a Thermister Kit. Has anyone outthere had this problem,and did this fix the problem? If so is this replcement something I can do or does it involve having a shop install it.
5wildcat
Sanford, NC
Posted: 05/20/08 09:22am Link  |  Print  |  Notify Moderator
I have the same model Dometic refrigerator as you and noticed this weekend that the coils were icing up on them. Is this the same issue you have? If so I will keep an eye on this thread for a solution.
By-the-way, My unit is under the Dometic recall and if I remember correctly, being low on refrigerant will cause the condensor coils to freeze up. (It has been a long time since I have done any refrigeration work) So if that is the case maybe this could be something to do with the recall. Hopefully someone with a little more knowledge in refrigeration will pipe in.
2004 F-250 FX4 CC PSD, P3 Brake Controller, Valley Hitch w/ slide
2007 Wildcat 32QBBS, 1 1/2 bath
DSteiner51
Wooster, Oh
Posted: 05/20/08 09:33am Link  |  Print  |  Notify Moderator
I have the same model and was told to slide the sensor up or down on the cooling fin inside the refrig. Just went and checked.. the temp is 34.7 on top shelf of the door. Haven't had any freezing problems with mine since I slid it approx 4 years ago and it hasn't been turned off since so it must work?
D. Steiner
The sooner I fall behind, the more time I have to catch up.
5wildcat
Sanford, NC
Posted: 05/20/08 10:55am Link  |  Print  |  Notify Moderator
D. Steiner, Thanks for the advice. Will try that.
ACZL
UPstate,NY
Posted: 05/21/08 02:43am Link  |  Print  |  Notify Moderator
Try not to place anything that will touch the fins in back of fridge. I seem to recall someone mentioning a Thermister on our clubs web site, but I'd have to go back and look.
2015 F350 XLT FX4, CC, SB, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
snowfighter
talmoon.mn
Posted: 05/21/08 05:59am Link  |  Print  |  Notify Moderator
Dsteiner51 which way did you slide the sensor up or down , my is also freezing things
2008 F350 FX 4X4 6.4 DIESEL AUTO SC 1999 CARDINAL28FT LX 2 SLIDES
donhov
near Jackson Michigan
Posted: 05/21/08 06:06am Link  |  Print  |  Notify Moderator
By sliding it up or down that is the adjustment for colder or warmer. In other words that is how you adjust the temp. Think up is warmer and down is colder but hopefully someone will correct if I am wrong.
2003 Cedar Creek 30RLBS
2007 Dodge 5.9 Cummins Turbo Diesel 325hp/610Tq
4x4 3.73 axles short bed
Inferno Red W/Gold pinstripping
DSteiner51
Wooster, Oh
Posted: 05/21/08 06:13am Link  |  Print  |  Notify Moderator
Old age... I don't remember. Last I messed with it was approx 4 yrs ago.
AGBAT
Tierra Encantada
Posted: 05/21/08 08:10am Link  |  Print  |  Notify Moderator
I have replaced the thermostat ($100 for the part) in a Dometic. It is not hard but does involve sliding the unit out and pretty much a total disassembly of the controls. The only "hard" part is getting the sensor back up into the frig compartment without damaging it. The thermostat may be working fine but the knob may not be. If the control knob turns with almost no resistance then it may not be turning the thermostat adjuster. If you decide to go into it take lots of pictures as you go along and label the wires.
Seiara
New Jersey
Posted: 05/21/08 04:38pm Link  |  Print  |  Notify Moderator
Thanks for all the responces I tried moving it down which is what Dometic support had told me to do to keep it from freezing, but with no success. I ordered the thermister Kit, now waiting 5 days for it to be shipped. I'll try this and will let everyone know the outcome. Thanks
