RV.Net Open Roads Forum: Beginning RVing: Slideout Question
 > Slideout Question
donee
Simi Valley, Ca. 93063
Posted: 05/20/08 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
Id like to know if anyone that has slideouts, use the supports Iv seen at CW?
Are they necessary or just a comeon?
Our unit has two slides and I dont want to mess something up.
Thanks.
05 Monaco Esquire 29PBD
05 Silver Dodge Cummins w/3.73 gears 4 spd auto.
grump daddy
Westland, MI
Posted: 05/20/08 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
I have a set that I used for one season hoping that it would help with the shakes that we had in our trailer, it didn't. If the trailer needed them to support the slide then the manufacture would have provided them I believe.
Bob & Arlene
DOMICILE Seaford, Delaware
Posted: 05/20/08 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Save your money and get some other item you need or want.
SKP member
2oldman
WA
Posted: 05/20/08 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
Don't use them.
RogerNCindy
umop episdn
Posted: 05/20/08 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
With your slide all the way out (and properly aligned) it should be sealed all the way around. If you add supports to it and the RV settles (it's a little heavier than the slide ) it could cause the slide to start opening at the top. It would at the very least cause stresses in directions not considered by the manufacturer. Neither would be a good thing.
As another said, if the manufacturer thought they were necessary, they would either include them or mention them in the manuals.
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Posted: 05/20/08 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
They should come with a disclaimer!
CAUTION! "Use of these slide out stabilizers may cause permanent damage to your slideout!" They can void your manufacturers warranty, cause slide out misalignment issues, leaks, frame damage, etc. Not needed!
scbwr
Wilson NY
Posted: 05/20/08 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto..........don't need 'em, so don't waste $$ on them....use it to enjoy campint!
2001 Dodge 3500 DRW V10 Magnum
2002 Sunline T280SR
Arrow Hensley Hitch
10' Porta Bote
My photo galleries.
tvman44
Southwest Louisiana
Posted: 05/20/08 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
Don't need them, in fact my dealer said they can damage your slide.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
mwallace61
Alabama
Posted: 05/20/08 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto the not needed.....
Mike & Karen
ForrestGump
Bumpyroad
Virginia
Posted: 05/21/08 07:05am Link  |  Quote  |  Print  |  Notify Moderator
what does your owner's manual say?
bumpy
 > Slideout Question
