novi2some
Novi, Michigan
I have two outside cargo doors that slide reward on their pivot points. They are the last two on the street side rear. They slide reward in time when travelling down the road. When they slide reward, the last door to the rear will rub the rear cap when opening the door. Anybody else have this problem? If yes, what did you do to fix it?
2006 Damon Challenger 355 pulling a 2008 Mariner
96Bounder30E
Birthplace of the Boysenberry, Orange County, CA
Do you mean rearward
sstgermain
Alamo Beach,Tx
I'm not too familiar with how your door is mounted but can you put a small self tapping screw in the track to keep it positioned properly. Or maybe drill a hole in the track and put a small pin in there
Steve . . . 2007 Lexington 283 GTS . . . Mini Cooper S Toad
Co Pilot . . Wonderful Wife and Partner in Life . . . Joy
Yogi . . Ranger Smith . . Teddi . . The yorkies.
Kissy . . . The Chiuaua
And I Believe that is it.
Ramblin_Mo
Mid-Missouri
96Bounder30E wrote: Do you mean rearward
I was hoping for a reward. I need to fill my tank.
robatthelake
Vancouver Island
I Have the same problem ! I just live with it, but then I'm just too lazy to put a screw in the hinge trim!
Rob & Jean 90 Southwind John Deere/Oshkosh/Freightliner Class A Ford 460/ Toad 92 Tracker 2 wd 5sp Convert Still running Great!
" Everything in it"Still" Works"
Flyteof4
Alberta
I also have the same problem on my 2000 Fleetwood Southwind. on mine there are small metal tabs that are screwed into the door frame at the top that fit into a slot in the door hinge to prevent the door from sliding forward or backward. The tabs are screwed in with only one screw so they seem to rotate a bit and the door ends up out of alignment. I've tried to make a new tab that's long enough to put 2 screws in so that it won't move but haven't had much luck getting it bent just right so that it'll fit into the door slot and let the door hinge work right...still looking for a better solution.
cam
Cam & Nicole
2000 Fleetwood Southwind F53 w/Banks
99 Tracker
Demco Excalibar
Microsoft Streets and Trips
Garmin GPSMAP 60cx
99damon
Colorado
On my Damon, a couple of doors liked to slide a bit, and bind when opening and closing. I fabricated spacers out of hard nylon/plactic chunks from the hardware store (intended use unknown). In any case, reposition the door, then install a spacer so that the door can't relocate itself in transit or just from using it. This solved my problem.
Wayne
Fulltimers
1999 Damon Intruder 341
novi2some
Novi, Michigan
Thanks for all the replies. I will see if I can come up with my own fix. If not, I'll try one of the suggestions.
