boonie
Canada
After much reading, I decided to lubricate my slide with Silicone spray as per the majority of posters on this site. Now it will slide out but not back in. It seems to get stuck at the top end on that little ramp requiring me to go outside and give it a helping hand. My questions is, what do I need to do to remove the "lube" so i can use something else in order to try and make it work again.
2003 Dodge Ram 2500 Quad Cab 4X4 Long Box 5.7 Hemi
2003 Coachmen Cascade 26RBS with a 14' Single Slide
The only practical use for that pistol is to fight your way back to the rifle you should not have dropped in the first place.
Hornet28BHDS
Parker, PA
It sounds like your slide just needs an adjustment. I doubt that the lubrication you used did anything to stop it from coming in.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
A1B00902
Vancouver B.C CANADA
It is possible that your slide is out of line,with the coach, try, when leveling, have someone open and close the slide slowly as you move your leveler up/down just a tiny bit of the other side of your coach, had it happen to me when the son-in law played at leveling up/down--up/down about 6 times before I had him stop Mike
boonie
Canada
I don't think that it is out of alignmetn as it worked fine prior to using the Silicone spray. I will check it though just to be sure...
ManInACan
Long Island
I use silicone spray all of the time. It is recommended. I doubt that is your problem.
Keep us updated.
2005 Gulfstream Conquest 30 BHS.
2003 Dodge 2500 CTD HO 48RE
Me,Wifey,J.R.,Fido
dbbls
Missouri
My dealer told me NOT to use silicone spray. There is a dry lubricant made especially for slides. I don't remember the mane but any RV dealer should have it. It is in a spray can.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
boonie
Canada
dbbls wrote: My dealer told me NOT to use silicone spray. There is a dry lubricant made especially for slides. I don't remember the mane but any RV dealer should have it. It is in a spray can.
I too spoke with the local dealer who told me that Silicone lube can cause your slide to stick and can attract dirt. He told me that they have a lube specifically for slides that cost $8.00 a can.
As for the alignment issue, I am 100% sure it is not that. I opened my slide to clean out my trailer for camping that weekend, closed it to go camping then realized I forgot to lube it. I then re-opened the slide, lubed it with Silicone spray lube and tried to close it but ran into this current issue.
At first I thought the batteries must be low from all the opening and closing but I left the generator on overnight at the campsite to charge them but it still would not close in the morning with out assistance.
SidKaye
Mt Dora Florida, Montreal QC for the Summer
All silicone sprays are NOT the same. Some will dissolve some plastics. Check the label and test on small area beforee using.
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, Hughes Direcway HN7000S, Satmex5,
http://www.kayepics.com
Hemisport
Prince George BC
Silicone spray should work just fine, we use it in the automotive industry all the time to lube weather stripping around doors. You could also try a graphite lube no mess from running oil..
But for now I guess you just need get your slide working
Good luck
LovemyDurango
Dieppe NB Canada
I use spray lube for motorcycle chains. It doesn't attract dust or dirt and last for a long time.
