RV.Net Open Roads Forum: Travel Trailers: Hot water heater help
 > Hot water heater help
russcue1
colorado springs, co
Posted: 05/21/08 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
You guys have been so helpful I figured I would try again. My hot water heater will light and stay lit for a few minutes then go out. Does anyone have any good solutions? I have had a few ideas but want to get a consensus. Thanks
javaseuf
Southern Cal
Posted: 05/21/08 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
If it is a DSI (electronic ignition), most likely a flame sensor.
If it is a standing pilot, could be the thermocouple.
These are comon scenarios and other things could also caust the same problem such as a defective board on the DSI model or a bad gas valve on the SP model.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
russcue1
Posted: 05/21/08 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry I wasnt very specific. It's a manual light system and the entire flame including the pilot light goes out after a few minutes. One time yesterday it did stay lit long ehough to heat the water but then went out again ( pilot light included)
robsouth
Near Atlanta, GA
Posted: 05/21/08 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
thermocouple.
Dodge Ram 3500 Cummins Turbo Diesel Dually
1994 Terry 22U
1997 Regal 1900LSR
Charter GA'RVers member
"Great minds like a think"
russcue1
Posted: 05/21/08 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
So can anyone tell me which one the thermo-coupler is? Is it the pilot light it self or the tube right next to it? Thanks
javaseuf
Southern Cal
Posted: 05/21/08 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
It is the very small "tube" that has a bulb inside the pilot light flame when lit.
It screws into the bottom of the gas valve. About $6.00 @ HD or Lowes.
It is NOT the 1/4" aluminum gas/pilot-light tube.
sagexpman
Loveland, Colorado
Posted: 05/21/08 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Check the plumbing for the gas that goes into the area where the flame is. I had a similar problem awhile back and it turned out to be a spider web which was preventing the proper flow of gas.
Rick
1998 HD Chevy Silverado 2500
- Super Charged Vortec 5.7
- Air Lift Suspension System
- Drawtite WD hitch with 1200# bars
- Drawtite DC sway control
- Honda EU3000IS
2005 Jayco JayFlight 31BHS
sweethome alabama
Scottsboro, Alabama
Posted: 05/21/08 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
The thermocouple has to be heated by the pilot light. If it doesn't then the heater will kick off as a safety feature. See if the pilot light flame is making contact with the bulb as a prev. poster described. It could be spider webs ect. blocking the flame. Pipe cleaners work well to help clean these out. Or could be bad if it is making contact with the flame. Same thing on windy days if the flame is blown off the thermo it will cut itself off. Hope this helps Mike
04 suburban 1500
00 silverado 1500
05 jayco 27bh
Couldn't get rig to post,so here is my burgler alarm!!
