RV.Net Open Roads Forum: Beginning RVing: Blackwater Tank
 > Blackwater Tank
sunnyvalesmostwanted
edmonton
Posted: 05/21/08 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
I am taking my fifth wheel out for the first time (never owned a trailer b4) and we are stayng at aplace with full hookups available. So, do i connnect my blackwater (septic) tank hose up to the hole in the ground at our campsite and keep the velve open all weekend so each time we flush it goes directly thru my tank into the campgrounds system? or do i llet it fill up oer the weekend and then empty the tank when we are leaving at the end of the weekend? I was planning on leaving th valve open but after reading a post below it seems like there is a chance that the solids can collect in my tank while the liquids go down into the campsites drain. Any advice would be appreciated. thanks
2008 Keystone Everest 348R
2005 F350 Crew Cab XLT Longbox 4x4 6.0 Powerstroke
Wonderful wife, son (12), daughter (4), son (new baby)
Dandy Dan
Findlay, Ohio
Posted: 05/21/08 11:15pm Link  |  Quote  |  Print  |  Notify Moderator
Best thing you can do is to put hose in the drain and leave the valves on the trailer closed, at least to the black tank. You can choose to leave the gray valve open. I leave both closed and also make sure there is liquid in the black tank prior to use. That way the waste won't get stuck to the bottom quite as quick. They also have stuff you can dump in the tank to help disolve the waste and paper and also help with the smell. by leaving both closed, when ready to dump do the black first then wash out the thing with the gray tank. Good Luck and Happy Camping
Dandy Dan
dan218b@tds.net
Dan and Lori Branson, Anna 1 (the rescue)
and Beau (waiting at the Rainbow Bridge)
2005 Dodge QuadCab 2500 4x4 Hemi
2009 Open Range 337RLS
RV.Net Ohio Rally Member
rnr42005
melbourne, fl.
Posted: 05/21/08 11:46pm Link  |  Quote  |  Print  |  Notify Moderator
many of your questions can be answered here:
answers
Rollincool
Always Rollin
Posted: 05/21/08 11:51pm Link  |  Quote  |  Print  |  Notify Moderator
Like Dandy Dan said, leave valve closed for black tank until almost full. It's nice to keep the grey water tank valve closed also since when you empty both tanks, (black first), then you flush the hose out with the grey water.
It's also a good idea to get some water into your black tank before you go poopin. Think of dropping mashed potatoes into a frying pan from 3 feet high. Now drop the same mashed potatoes into a bathtub full of water. See my point? You'll get "poop pyramids" in your tank if you don't. Then you have to flush and shake and flush and what a pain in the _ _ _!!
Enjoy.
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Yellowstone 5290 6.0
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
The Most Fun Radio, on Radio - Tom Kent Radio Network
Bumpyroad
Virginia
Posted: 05/22/08 04:54am Link  |  Quote  |  Print  |  Notify Moderator
the best money you can spend will be on a tank sprayer system, fairly cheap and you can dump at your convenience, not wait until it is 3/4 full. Actually the best purchase would be either a sewer solution or macerator pump and get rid of that stinky slinky. it changes the worst job of RVing into a fun experience, OK maybe a slight exaggeration.
bumpy
tenbear
Northern Vermont, USA
Posted: 05/22/08 06:29am Link  |  Quote  |  Print  |  Notify Moderator
Here is how I do it. This assumes you use your shower for the purpose intended. If you are in a CG for one night leave the valves closed then in the morning before leaving, fill the black tank to 2/3 with water and dump it, then dump the Grey tank. I don't like to travel with full tanks. For longer stays, leave the grey tank valve open until the day before you are going to dump then close it. Keep the black tank valve closed. When you dump, fill the black tank 2/3 with water then dump and dump the grey tank after the black. Whenever you dump, put a few gallons of water into both tanks after you dump.
Never leave the black tank valve open. The liquids will drain out and leave the solids in the tank.
2004/5 Four Winds Dutchman Express 28A, Chevy chassis
Subaru Impreza Outback
jimgoss
Northbridge
Posted: 05/22/08 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Enjoy.
That's nasty!!!!
NFD.E-4 LT. JAG
2005 Jeep GR Cherokee LTD
Factory Tow Pkg.
Blue OX WD + Sway Ctrl.
Starcraft Travelstar 21SB
Wife, 2 kids and American Eskimo Dog
edmonton
Posted: 05/22/08 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
awesome, thanks for the info guys. i am going for 4 days so i will prob leave the grey one shut and then dump black on last morning and grey to follow. as for adding water to the black to fill to about 2/3, how do i do that? just flush the toilet a million times ?? thanks
tenbear
Posted: 05/22/08 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
On my toilet I can hold the flush lever so that the flapper valve stays open and water runs into the toilet and into the tank.
PatJ
WA
Posted: 05/22/08 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Check and see if your bathroom sink drains in to the black tank. I think it is pretty common, as I had a trailer like that. I used to just leave the bathroom sink on for a bit and look down the flapper every few minutes until I was close to full. The tank level indicators can never be trusted.
Patrick
 > Blackwater Tank
