RV.Net Open Roads Forum: Fifth-Wheels: tornado rotary tank rinser
 > tornado rotary tank rinser
taco5er
mount vernon indiana
Posted: 05/21/08 11:23pm Link  |  Quote  |  Print  |  Notify Moderator
has any one used one of these tornado tank rinser . i just put one in my black tank any pro or cons any help thanks.
oujoker
Monterey, CA
Posted: 05/22/08 01:22am Link  |  Quote  |  Print  |  Notify Moderator
I have one in mine, I run it for about 5 mins following dump. Works great for me. Be sure to use the included regulator or you might blow the hose off the fitting with too high of water pressure.
2007 Dutchman Express 31 Class C
2006 Centurion Elite V C4, Air Warrior
Bumpyroad
Virginia
Posted: 05/22/08 04:51am Link  |  Quote  |  Print  |  Notify Moderator
I have a rinser, not that one, and can't think of any cons to them.
they permit you to dump the black tank any time you want to, at your convenience. IIRC I have heard here that they might hang up and not rotate but don't know how that affects the cleansing?
bumpy
Geozzz
South Jersey
Posted: 05/22/08 05:19am Link  |  Quote  |  Print  |  Notify Moderator
Have Tornado on both my black and gray tanks and no problems. Use them at each dumping for a minute or two.
Kathy & George Zimm
Mickleton NJ
2006 Coachman Epic and 1 Sheltie
Fire Instructor
Upstate (Albany) NY Area
Posted: 05/22/08 06:15am Link  |  Quote  |  Print  |  Notify Moderator
We had previously installed a Tornado Flush on our HTT that we traded in this Spring, and we like it so much that it was the FIRST modification that we completed on the new TT!
Fire Instructor
2004 Dodge 1500 4dr 4x4
2009 Rockwood 2607
"If everyone is thinking alike, then somebody isn't thinking!" General George S. Patton
dgo1369
Georgetown, TX, US
Just out of curiousity, why would you install one THEN ask about its' performance???? Idle minds want to know!
Dennis Osha
flhtse05
Pace, Florida
Posted: 05/22/08 06:23am Link  |  Quote  |  Print  |  Notify Moderator
Had them installed in both black and grey tanks. Dump then flush with about 10 gal of water then dump again.
USA in a Chevrolet
Manahawkin, New Jersey
Posted: 05/23/08 10:20am Link  |  Quote  |  Print  |  Notify Moderator
I installed one in my brother's TT. I have the factory installed one on my Designer fiver. They do work great but I would advise you to get one of the clear 45 degree connectors to put on the end of your trailer sewer line & then attach your flex dump hose to the clear adaptor. Flush the tank until water runs clear to make sure you got as much as possible. I close my black tank valve after flushing & add more water to the tank using the flusher & then drain it again with the flusher still running. The directions with the flusher say to never run the flusher with the valve closed but I hope that is because they don't want you leaving the water running & forgeting about it as this will overflow your tank & could damage it. I always do this while I am paying attention to the process to avoid this potential problem.
snownyet
Western NY
Posted: 05/29/08 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
A buddy and I both installed tornado rinsers in our 5th wheels when new. They work great but last yr my buddys backflow preventer cracked and caused it to leak when flushing, he replaced it and its been fine since. Second trip out this year and mines got the same leak, I have yet to tear the underbelly off to verify but it only leaks when Im rinsing so Im certain its some sort of issue with the tornado.
2007 Montana Mountaineer 307RKD
2006 Chevrolet 2500 4x4 crew Duramax/allison
