bukhrn
Lanexa, Va
For those that change thier own oil, where do you do it while on the road, I'm sure a dealer or truck stop will do it, but what if you want to do your own?
2007 Forester 2941DS
2005 KIA Spectra
I Love My Grizz
amxpress
Clayton, NC
I saw a class "A" parked at an auto parts store, legs sticking out from under it. The guy was changing his oil. Looks like he had an oil drain pan.
I guess if you buy your oil and filter there, they might not mind. Ask the store manager, the worst he can say is "NO". You can usually dump your old oil there, too.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2008 Palamino Sabre 31RKTS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Travel in peace, leave the M-I-L at home.
VDOCAD
Arcadia, CA
I did the best oil change of my life in ST. Petersburg, FL, as soon as we cleared the bridge coming from the South, overlooking the bay. I parked so the front of the rig would not be exposed and later refilled empty milk jugs with the old motor oil that I turned in at an Advance Auto Parts in Tallahassee a couple of days later. It was risky, I know, but I did not allow a drop of oil to contaminate that beautiful sand. Anyway, you know how many rigs drive around with a permanent oil leak...
You just have to find a quiet spot and do it really fast. And make sure you do not leave a mess behind.
2oldman
WA
This would be tougher to get away with than dumping gray water on the shoulder of the road in broad daylight.
The best you could hope for is going somewhere out in the boonies where NObody else is around. NO campground will allow it that I'm aware of. Then you gotta carry the old oil around. What have you got against a shop doing it?
Your best bet is to limit your trips to 3-5000 miles.
smkettner
I would easily run 10,000 maybe even 15,000 just topping off the oil until I returned home.
Mine also calls for 5,000 mile intervals.
I do run Mobil 1 synthetic if that helps.
edited 05/22/08 10:16pm by smkettner *
Puddles
Lafayette, Indiana
Add a by-pass oil filter such as oil guard, etc... they will allow you to increase mileage between changes... 15,000+ That's should cover most trips, unless you're full timing.
HTML
westernstar
Very Very Farwest Oregon
drain the old oil out, dump it in your fuel tank, put in new oil, drive on.
Savage Rapids Klamath river smoke from Happy Camp fires 07
bobsallyh
Livingston, Tx.
Being fulltimers we have had little problem changing oil. I do my own maintenance. When I'm due or close I'll ask at the park where we are. Only been turned down once. I carry an oversized drain pan and a tarp to lay on the ground. The old oil goes in the empty gallon jugs that the new oil has just been poured out of. Then it goes to Wally World, Checkers, Shucks, etc. I have had several park owners have me go to their maintenance shed area. No problem. Also we are Escapees and most of their own parks have a maintenance area provided to do this job.
Kenneth
Washington, the state
bukhrn,
How many miles does your owner's manual call for between oil changes? You can extend that a bit, and there is no good reason to change the oil any sooner.
bukhrn
Lanexa, Va
Kenneth wrote: bukhrn,
How many miles does your owner's manual call for between oil changes? You can extend that a bit, and there is no good reason to change the oil any sooner. It calls for 5000 mi.,which it will have, by the time I get to, roughly Billings,MT., but then it's another 3700 back home, I don't want to extend it that much.
