RV.Net Open Roads Forum: Using Blue Boys to dump in home sewage system
 > Using Blue Boys to dump in home sewage system
scrappy 73
New Jersey
Posted: 05/22/08 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
Have wondered about the use of Blue Boys to dump in home sewage system.Rather than using the macerater type system,is there anything on the market which would pump from a blue boy to the commode ? Would this be more cost effective. My rig is about 25' from my commode!
hershey
Albuquerque,(fulltime) NM, USA
Posted: 05/22/08 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
You really should perhaps rethink bringing in your sewage into you house and commode. Really not a good idea from a health standpoint and just plain housekeeping standpoint.
Surly you must have a cleanout that is accessable. If its no more than 2 feet above your dump valve a Sewer Solution will pump a hundred feet and that much lift and is really a much cleaner operation than trying to use a blueboy and cost is about the same. Even if you use the blueboy to dump outside to the sewer cleanout would be a better idea. YMMV
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
2oldman
WA
Posted: 05/22/08 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Heck, just pour it in the commode. Very carefully.
skipnchar
Topeka Kansas USA
Posted: 05/22/08 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Surely you have a clean-out somewhere outside you could just pull up next to and avoid carrying that stuff around. Very few folks have the guts to use a portable for hauling black tank contents but maybe you're a lot braver than most. Must be if you're considering taking it inside the house. Good luck / Skip
ozhoo
Donnelly, ID
Posted: 05/22/08 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
moving all that poo through the toilet is going to run you out of the house. Find your sewer cleanout and use a macerator to move the poo. I have a 25' 1" hose on mine that I refer to as the "target radius".
O
2003 F350 6L 4X4 Auto Dually
2003 KZ36P2 Off-Grid Toy Hauler
1 retired sailor, 3 bikes and a world to see...
08f450psd
Westminster, Maryland
Posted: 05/22/08 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Ask your DW (assuming you're a guy) what she thinks about your possible solution and post the results here to amuse us. I assume you're a guy, cause I can't imagine a woman thinking about dumping all that in the commode from a blue-boy.
Pete D
Washington
Posted: 05/22/08 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
I've tried once or twice just emptying a relatively full porta-potty into flush toilets and it's still messy. Find or install a clean-out and do your emptying outside where you can hose it down.
1998 Ranger 4.0 4x4
1991 Scamp 13'
2oldman
WA
Posted: 05/22/08 11:34pm Link  |  Quote  |  Print  |  Notify Moderator
No way..!! lol. Definitely WAIT until she's gone for a few hours before doing this. And be prepared to air the place out real good before she gets home.
And heaven help you if you spill anything.
Bumpyroad
Virginia
Posted: 05/23/08 05:22am Link  |  Quote  |  Print  |  Notify Moderator
why would you go thru this hassle instead of just buying a macerator pump or sewer solution?
bumpy
RJsfishin
Winston Or.
Posted: 05/23/08 07:52am Link  |  Quote  |  Print  |  Notify Moderator
scrappy 73 wrote:
Rather than using the macerater type system,is there anything on the market which would pump from a blue boy to the commode ? My rig is about 25' from my commode!
Lets see,..you're down on macerator pumping,
the RV is only 25ft from the commode,
And you're thinking of transferring to a blueboy first,
then lugging the blueboy into the house, and pumping it into the commode.
Something is wrong here. But I'll decipher it a little more before I comment
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
