mcoonan
Mendota Heights, MN
Need some advise on what to do! While flushing the water system, the tub became plugged and overfilled, flooding the TT. The underbelly wrap was full of water (just on the left side, TT is angled to that side). Insulation under the floor is soaked. I know that I will need to pull all the insulation out and replace. Once that is done, how do I reseal or resew the underbelly wrap? What else will I need to do? I have fans running in the TT, there did not appear to be much water on the floor, just in the underbelly. Any and all advise welcome!
Thank you in advance!!!!!
Mike
'05 Cherokee 28DD
'04 Expedition w/HD tow package.
Hensley Arrow and Jordan Ultima 2020
2oldman
WA
Oh brother.. have you asked your tt maker what to do?
mcoonan
Mendota Heights, MN
2oldman wrote: Oh brother.. have you asked your tt maker what to do?
Just happened 20 min ago. Tried to call dealer, they are closed for the night.
skipnchar
Topeka Kansas USA
You were using the flush system to clean the tub? Sorry but I guess you now know it's supposed to work in the black tank only. All I can suggest is dry everything you can see and blow fans everywhere you can't see. Good luck / Skip
Perrysburg Dodgeboy
Perrysburg, Ohio USA
If you have a dehumidifier get in there and get it running along with the fans, if you don’t find one or rent one.
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
pics
ezymony
Wellington Alabama
I would punch a very small hole in the underliner to drain the water out then do as others suggested with the fans and dehumidifier to dry things out.
mcoonan
Mendota Heights, MN
Perrysburg Dodgeboy wrote: If you have a dehumidifier get in there and get it running along with the fans, if you don’t find one or rent one.
Don
Man I did not even think of that, gonna do that right now!
Thanks
Mikeyxx
Hamilton, Ontario
Also, go rent one of those floor fans. They are those ones that look like a conk shell and blow air on floors to dry them in commercial establishments. They push a LOT of air.
taborekle
Clements, Md
Unless this is black filthy water, I'd just let it dry out. I don't think you're going to get mold and mildew in the insulation from just a single short exposure to water. Dry it out, clean it up and forget about it.
Larry
Earl E
Klamath Falls, Oregon
I would agree with Larry. I'd probably just dry everything out and forget about it. But no guarantees with my cheap advice! LOL
2008 Keystone Springdale 252
2004 Chevy Silverado, 5.3 L V8
Prodigy brake control and Equal-i-zer
Retired and traveling all we can!
