Fulltimers
Anywhere, USA
Does anyone have any experience with antennas for a Verizon broadband pc card?
I am presently in Lake Havasu. There is no Verizon here in Havasu however it is across the lake on the California side. My PC5750 PC card is running at National Access speed. Sometimes I can connect at Broadband speed but after a minute or less it drops back to National Access. I believe when it connects at Broadband speeds it is picking up the signal from the California side of the lake.
I am looking at the 13dBi External Booster Antenna To Verizon/Alltel PC5750. My question is will this antenna pick up and stay locked on the signal across the lake? Do you think this antenna needs a ground plane? I will be setting it on top of my fiberglass motorhome.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2001 Saturn SC2 (Mr. Toad
Photos
hershey
Albuquerque,(fulltime) NM, USA
I don't know about your particular aircard, but the USB720 has a jack that you can plug in the Wilson Antenna. It certainly does help in those fringe areas.
hershey - albuquerque, nm
Someday Finally Got Here
NASCAR 20 - - 99
YC 1
Yuba City Calif.
If your card does have the direct connection to go to the antenna then the cost is well worth giving it a try. Getting a decent size antenna and being able to move it to an optimum location can make a tremendous difference.
MELM
GA
Moving to Technology Corner from Tech Issues.
SPacheco
Rhode Island
We have a Verizon BB card plugged into a wireless router (we sometimes have multiple computers on board). We have a Wilson antenna mounted to the windshield and that seems to help.
We have been up and down the east coast (95 and 81) and have had very little trouble with reception.
Steve P.
http://micasademilonga.blogspot.com/
jmanatee
Willington, CT
I have the Wilson amplifier http://www.wpsantennas.com/index.asp?PageAction=VIEWPROD&ProdID=2
and the Wilson Truckers antenna. http://www.wpsantennas.com/index.asp?PageAction=VIEWPROD&ProdID=3.
I am not sure where I bought these this is just where I googled them this time.
I also got a suction cup thing http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46134 and use it to mount the antenna only when needed.
This setup works Excellent.
I have Full strength every where I have used it. Before I would have only 1 bar in some places.
Jon
Our RVing Web Site | Our Roof Replacement Project
Twenty years from now you'll be more disappointed by the things you
didn't do than by things you did. Explore, Dream, Discover. Mark Twain
1992 32' Georgie Boy Swinger
Magician
Belleville, ON
I can't speak to your particular situation but I can share experience. In situations where service is marginal, an antenna can and usually will make a difference with improved signal strength and the resulting improved speed you'll realize from your air card. I use a pizza pan under my antenna for a ground plane.
Eating an occasional Pizza provides the chance to see if the antenna really does make a difference.
MCP, IEEE, CCP, BJCP
Traveling, Working, and Judging
ed6713
FL
An external antenna *plus* a cell phone booster will yield a very noticeable improvement in your speed & your ability to operate in marginal areas. Sometimes it makes a difference between no reception and poor reception; a huge improvement.
If I get one "bar" of service without the antenna/booster combo, then attach the antenna/booster, I usually jump to 3 "bars".
Pete D
Washington
I always wonder if the bars are measuring the connection signal to VZ or just the connection signal to the booster... Any one know for sure?
1998 Ranger 4.0 4x4
1991 Scamp 13'
JTMO
Novato, CA
Pre-broadband aircard several years ago we used those in our trucks. Made a BIG difference in connectivity.
Go for it.
Cedar Creek 27LRLS 7359 dry with extensive options/7700+ loaded.
2003 Expedition 5.4 FX4 with factory Tow 3.73 Bilstein shocks. GCVWR 14500, Tow rating with no cargo 8650
Equalizer Hitch, Prodigy, Barker Electric jack. Coachnet ERS
Rallies=8
My travel albums
