RV.Net Open Roads Forum: Tech Issues: Replacing rooftop AC
 > Replacing rooftop AC
cephoto
Hemet, CA. USA
Posted: 05/23/08 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
I have to replace my rooftop AC unit on my 5vr. It was a 15k Coleman(ducted) and I'm looking for any advice on better units(Duo Therm? Carrier?) and what I might look for in a new one.
* This post was edited 05/23/08 04:09pm by cephoto *
CEPhoto
Kenneth
Washington, the state
Posted: 05/23/08 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Why a "better" unit? The three brands, Coleman, Dometic, and Carrier are all good. You might look for a high efficiency unit...same cooling using less electricity.
crazyhorse
San Diego
Posted: 05/23/08 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
check these guys maybe you can get different kind. and get good pricehttp://www.azrvinc.com/
Admiral
The Buckeye State
Posted: 05/23/08 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
I've got a 15,000 btu rated Carrier that I believe to be substandard compared to Dometic and Coleman units I've had. In comparing the unit's output with others I'm guessing it's putting out a paltry 11,000 btu. Had it checked while under warranty and Carrier said that it was working up to capacity. I would vote not to get one of these!!
2004 Damon Daybreak 2960F
05 Honda Element LX
In a democracy two wolves and a sheep can vote on what to have for dinner.
cephoto
Hemet, CA. USA
Posted: 05/24/08 06:01am Link  |  Quote  |  Print  |  Notify Moderator
Although I feel for you, this is the kind of feedback I'm looking for. Experience not generalities. I am surprised as I thought Carrier was a "premium" brand.
dcarpenter252
Timmonsville,SC
Posted: 05/24/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
I am not going to try to say which unit is better, but I will say that I repair more Colemans and replace more Duotherms????
The Coleman seems to have A better compressor but weaker compontents such as controll boards,thermostats,capacitors and fan motors. The Duotherm seems to have A weaker compressor but the other componentents seem to be better.
I havent had much dealings with the Carriers.
Hope this helps.
Dennis
2004 Beaver Santiam 40PDQ
2002 F150 4WD
1995 Jeep Cherokee
Chris Bryant
DeLand, Florida, USA
Posted: 05/24/08 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Something to look for is how the thermostat is wired- for a "standard" DuoTherm, the Coleman install doesn't use enough wires, so you would have to run new thermostat cables (the DuoTherm bi-metal setup would work without modification, though).
The Carrier ducted unit is typically sold with the remote thermostat, which I really dislike, as the temperature sensing is done in the air return, and isn't very accurate for heating.
On all of the brands, the vast majority of problems I run in to are installation problems.
If it were me, I would replace it with the same thing.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
Bob Landry
Austin, texas
Posted: 05/24/08 09:09am Link  |  Quote  |  Print  |  Notify Moderator
The Duotherms are very prone to air flow issues/icing. Especially if it's installed as a ducted system. The manufactuers don't seem to be able to get enough air flow. Each brand has it's own set of problems, but control/thermostat issues are a lot easier to deal with than a unit that can't be installed in a manner that will function properly regardless of what you do to it. If you have a unit that was installed incorrectly, it doesn't matter what you replace it with, you won't be happy with it. I have to agree with Chris about the installation issues. I have yet to see a marine installation from a builder that doesn't leave the factory without issues. I see more old Coleman units running than Duotherms.
96Bounder30E
Birthplace of the Boysenberry, Orange County, CA
Posted: 05/24/08 10:29am Link  |  Quote  |  Print  |  Notify Moderator
I'd never buy anything from Dometic willingly..........I feel Dometic is a very unfriendly company to work with.......
cdl2
ohio
Posted: 05/24/08 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
I put in a Polar Cub on my TC. It's only 7000btuh, but I think they make bigger units. I got it because it had elec heat for it. I don't winter camp, but it does take the chill off when it's a little cool outside.
Just something to look into & evaluate.
'97 Safari Serengeti, 300 Cat ; '89 Lance LC900 w/Stable-Lift
