REMFISH
Palmdale, Ca
Not sure if this is the correct forum...but here goes.
Are there any antennas available for RV's that are digital ready? In Feb 2009, my "batwing" antenna will be useless without a converter. However, we mostly stay at campgrounds without hookups and I don't want to run the generator just to watch an occasional TV show. I plan to purchase and AC/DC LCD TV/DVD that is digital ready, but need to upgrade my antenna. Please do not suggest a satellite system...we aren't that desperate!
R.E. May
dons2346
Sioux Falls, SD, formerly of So. CA
It is not the antenna that has to be digital ready, it is your TV. An antenna is an antenna. It does not know the difference between analog and digital signals. Lots of reports on the forum from people stating their batwing works great for digital TV.
This should have been in Technology
2oldman
WA
Once again..
batwing/digital post in Technology
HedoTravelers
Rochester, New York & Jamaica, W.I.
I have a WInguard "bat wing" style antenna... works great with our HDTV. Better than ever actually.
There is no need to get a new one.
Respect,
Brent
TV ~
Cadillac Escalade EXT, Prodigy BC, Reese Pro Series SC
Rigs ~
Starcraft Travelstar 21RBS, Alcan Traveler Tent Camper
"Where ever you go, there you are"
fncampn
Gardnerville, NV
Yup. Mine too. Just make sure your TV has an HD tuner in it and you will be fine. Otherwise, you will need another TV and/or converter box.
Cold Weather Camping Mods
A Bunch of Ways to Mod Your RV
'08 Ford F150KR Screw 5.4L LB Auto 3.73LS 4x4
'07 Ford F350 XLT CC LB PSD Auto 3.73 4x4 - SOLD
'08 Thor Summit 27RBS TT - 9000 GVWR, 7500 loaded, 875 TW
'06 Kipor 3500Ti Generator
Oakman
MO
As mentioned your antenna doesn't need to be replaced. In Feb 2009 your analog TV will be useless without the converter. Since you're planning on buying a new TV make sure it has a built-in ATSC tuner, without it you will still need the converter box.
2002 Dodge 2500 V10
2008 Wildcat 28RKBS
Honda 2000 gen
TomTom One 3rd edition GPS
Enjoying the Lagniappe
Destin,FL,US
Your current antenna will work fine. It is your TV that may need the converter. If your Tv does not have a digital tuner (you can't tune to channel 77.1 or 77-1), you will need a converter.
It is not the antenna requirements that are changing, but the tuner requirements.
Wherever I happen to park
It is not the antenna, but the television, that will be "Useless without a converter" Odds are that your Batwing is a VHF/UHF model (NOTE: the original batwing was VHF only and is NOT digital ready, but that is only the original,later models are VHF/UHF and any VHF/UHF antenna is digital ready)
how to tell.. VHF-High band is channels 7-13.. UHF is 14-69 (Currently) at one time it went all the way to 83
Digital in most markets will be on UHF channels 14-59 only
In a few markets they plan on using 7-13 (VHF-High)
So if your existing antenna works well for analog on those channels
Then it will work for digital too.
I spend a few hours a day watching digital TV on an analog antenna, works great
I also do 2-way digital work using the same antenna, IN FACT THE SAME RADIO, I do 2-way analog voice work with... NO difference in the antenna at all.
Rev.
Troy, TX
My dad just recently got the converter for his TV at home and one for his trailer. He didn't get a "HD" antenna for the house TV. So, I just hooked up his 25 year old rabbit ears (no UHF loop) and it picked up all the HD channels with no problem. In fact he picks them up better than I do with my HD antenna! On the trailer again no problem with the batwing antenna. So, don't worry about the antenna.
Blessed Camping,
Rev. (aka: Preacher)
2003 Ford Expedition 5.4L, 3.73 tranny
2008 Nissan Sentra (great gas milage so I can afford to go camping!)
2008 Pilgrim 1500 lite - 26pfk
Wadcutter
IL
Point of order...
Unless you have an HD TV it doesn't matter what kind of digital converter you buy, you won't get an HD picture. Too many people think digital is the same as HD. It isn't. All the digital converter does is change the digital signal coming in from your antenna to an analog signal to your TV. The digital converter cannot change your non-HD TV to HD TV no more than it can change your black and white TV to color. You'll no doubt get a clearer picture with digital but it's not HD.
Camped in every state but Alaska
