Deen
Vancouver, WA
dbates wrote: According to what chassis you have (Ford or Chev.). Our local Ford service center will change the oil & lube "most" of the grease zirks. Because they don't have a pit or hoist big enough for a MH he can't get to all of the zirks. His charges (with oil & filter) just under $26. I found a local truck service center that will do everything for about twice that much. Which is still 1/2 what the RV dealer was charging & they are 80 mile away. Since my maintenance manual says to lube every 2nd time the oil & filter are changed I rotate between the two.
Dave What zirks can't they get to without a lift? I do all my service including oil, filter, transmission fluid, filters and lube and I don't have a lift.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
coloradodave
Colorado Springs, CO, US
Most places here won't touch a MH, either won't fit thru the doors, or they don't have a lift big enough, or something. Found a local shop that will work on em for fairly reasonable, although they have had a # of price increases in the past year (still cheaper than the RV places though). Just need to call around to a few places, or DIY.
'04 Coachmen Mirada 300QB
DH & DW
DS & DD
2 dogs
gardnergang
Brighton, MI
$59.00 plus tax is outstanding. I just purchased the oil filter and oil to do mine and I paid $10.00 for the filter and $51.00 for the oil(5gal.)
99 Monaco Diplomat 38A
mtrumpet
Hamburg, NY
If you're somewhat of a DIY'er, it's actually easier than a car. There's a lot more room to work underneath and no, you don't need a lift to do an oil and lube job on the MH. Frankly, I'd rather do the oil/filter and grease job on the MH then on mine and my wife's cars.
mtrumpet
2000 Southwind Storm 30H
Ford Triton V10 6.8L
F53 Chassis
Davis Tru-Trac
Henderson Rear Trac Bar
Carquest/Moog Steering Damper
Monroe RV Gas Magnums
Goodyear G670 RV's
freerider1
Pembroke Pines, FL
My husband does ours all the time & has had no trouble doing so.
He does the oil change on the generator, & the engine & whatever
he has to do to the transmission. I believe he does the air filter
on that. He puts the old oil into the old bottles & takes it to NAPA or some one who takes & disposes of the old oil. When it is time that the generator & or transmission needs the big stuff done he will take it in. Why pay someone $300 or more to do something you can do yourself unless there is a physical or handicap issues. That money will help buy gas/diesel now. It just takes a little time.
safe travels & make alot of memories
freerider1
Berjmobile
El Cajon, CA
I would like to do it myself as the other posters have stated. I don't know anyone who will show me the ropes . One wrong move on engine lubrication and the engine will have a very short life. So, I bring my coach over to the Cummins dealer and they do it for me. Jim
JAG
1993 Pace Arrow Diesel
2004 Saturn VUE V6 AT
El Cajon, CA
Cloud Dancer
San Antonio and Livingston TX USA
I have all my maintenance work, and repairs, performed at Willie's Shade Tree Garage (in my backyard). Getting rid of the old oil is not a problem.
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
Johnny Hurryup
Tafton Pa.
When you "Do it yourself" you know it gets done right.
Cloud Dancer
Johnny Hurryup wrote: When you "Do it yourself" you know it gets done right.
Not only that, but you don't worry about schedules, losing anything out of the motorhome, or spending additional monies.
69RoadRunner
VA
If you have a diesel, just make sure you have a large enough container for the old oil.
If you want to make the job even easier, get a Fumoto valve.
09 Newmar Ventana 3942
