lukewarm
sarnia onatrio canada
Is towing a 5ver cheaper on fuel than a tt /
Chris
Shelter Bay, Wa
Depends! Chris
My Rig
2001.5 2500 STD CAB AUTO SLT 4x4, CTD 4:10's, Bomb'd to Tow
2005 Cardinal 29WBLX.
dbbls
Missouri
5er's are taller, more wind resistance. They are generally heavier because they are generally bigger. This means more fuel.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
Penhall
Whitehorse, Yukon
5ers are often more aerodynamic, sit differently behind a tow vehicle
TT's are often pull behind bricks that the wind can catch.
So I agree with Chris' answer: Depends.
All else I can say is personal experience is that I get the same fuel mileage pulling by 10K - 29ft 5er than I did pulling my old 20' travel trailer at 1/2 the weight over the same routes. TV is a 6.0l deisel.
2oldman
WA
Depends on the nose and rear cap of the Five-ver - I mean fiver.
robbins
Sonora, Ca
My 33' 5er pulls easier than the 24' TT I had. My mpg seems to be the same.
See 'ya on top
Keith
2004 2500HD silverado 4x2 extra-cab
265/75/16 Hercules tires
Reese 15000 Pro Hitch
2006 Gulf Stream 30FBRG
GlacierBayGuy
Holland MI
I get 9 mpg pulling our 29' 10,500 lb. fiver with a '06 Chevy 6.0 gas and got 8 mpg pulling our 26' 6,000 lb. TT. ???????
100ton
Huntington Beach, California
Concerning the post's above in which MPG was the same or better when pulling a larger 5th wheel. Just wondering, is there any chance that you were pulling the smaller units at a greater speed, thus decreasing your MGP? Note: I am not trying to discredit the poster's in any way, I am just happy to hear the good news! LOL.
See you out there,
Robert
'05 Ford F250 Crew Cab, PSD, 4X4, Short Bed, Camper & Tow Package, Limited Slip Differential
'05 CrossRoads, Cruiser 29RK
PullRite 16K SuperGlide
usmohls2@yahoo.com
CA
I pulled our 5er a little faster, because most of the time you don't know it's behind you they tow so well. Could it be: that you are carrying 1/3 of total weight on the back axle of the rv?
portablevcb
Tijeras, NM
I have towed a lot of stuff over the years. Cargo trailers, covered utility trailers, fivers, cars on trailers, popups, etc.
The gas mileage is related to the effective frontal area. So, you can't say that any fiver will get better or worse mileage than any TT. One 28ft, 6000lb fiver of one make will have different aerodynamics than another of same size and weight from another mfg. Same for TT's.
For example, on flat level ground and no wind. Towing the 24ft fiver (6000lb) I get 10mpg. Towing a 6x12 covered cargo trailer (inside is 6ft high) I get 12mpg (even when it is empty-less than 1000lb). Both at 70mph.
charlie
2006 Toyota Tundra Crew Cab
2003 Skyline Nomad 24ft Fiver
Me and Wife
Maggie the Old English Sheepdog
