whattoget
Boston Area
anyone have a good place to buy weight distribution bars?
I am looking for 1100 - 1200 trunion style bars.
my current system is reese but I can work w/ other types.
thanks.
BarneyS
S.E. Lower Michigan
Many folks here have had good luck with E-Trailer.
Free shipping if your order is over $150 (which it would be, just barely, for two bars).
Barney
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the new RV.net Blogs!
Visit our website here
reno82
Cardiff by the Sea, CA
Yep, just ordered some 1200's for $139 for the set with chains, added a new ball to get the free shipping. Etrailer is the way to go.
rlc323
Illinois
Another happy etrailer customer here. Nice people to deal with, and very good prices.
2002 Chevrolet Avalanche 1500 Z-71
2002 Trail Lite 8261
SoCalDesertRider
SanDiego, CA, USA
I have ordered from e-trailer a few times over the last few years and they are always great to deal with, have good prices, very fair shipping rates, and on-time delivery.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
TXiceman
(Near) Houston,TX
Try www.rvupgrades.com
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
whattoget
Boston Area
thanks guys. i will check them out
Draggo
Rochester, NY
I have decided that I need to get some new spring bars. I currently have the Reese Dual Cam system with 800 lb bars which worked fine with our last trailer but now my tongue weight is 750 "dry" so I know I'm over 800 lbs. I was thinking about going with the 1,000 lb bars but don't see them listed on the E-Trailer link above. So now I have 2 questions:
1) Are the 1,000 lb bars still available?
2) Do I bother with the 1,000 lbs or just go with the 1,200 lb ones?
Thanks,
Mike
Mike & Company
2002 Chevy Silverado 1500 Ext Cab(5.3 L V-8, 3.73 rear gear)
2008 KZ Spree 318BHS - Can't wait to use it!
Reese W/D & HP DC, Prodigy brake controller
BarneyS
S.E. Lower Michigan
Draggo wrote: I have decided that I need to get some new spring bars. I currently have the Reese Dual Cam system with 800 lb bars which worked fine with our last trailer but now my tongue weight is 750 "dry" so I know I'm over 800 lbs. I was thinking about going with the 1,000 lb bars but don't see them listed on the E-Trailer link above. So now I have 2 questions:
Thanks,
Mike
Yes, 1000# bar are still available but are in the round bar configuration. I am assuming you have trunnion bars since you said your previous bars were 800# and the next size up for trunnion bars is 1200#. For that trailer, I would go with the 1200# bars anyway. Your tongue weight is very likely going to be over 1000# when you are loaded and ready to travel.
Barney
Draggo
Rochester, NY
Barney,
Thanks, yes I have the trunnion bars and wondered if I should just go with the 1,200s just to avoid having to buy new ones again in the future. I checked out E-Trailer that was listed above and they seem to have a pretty good deal on them. I called a couple of local places that wanted ~$20 more each. I've got one more place to check out and then I will get them.
Thanks,
Mike
