PsnRebel
On My Banshee, In the Dunes !! In SoCal
Whats the purpose of a battery box anyway? Cars don't have 'em.
BShivers
North Texas
PsnRebel wrote: Whats the purpose of a battery box anyway? Cars don't have 'em.
I believe;
1) to catch any liquid that may spill/leak out.
2) they should have a top on them to fully enclose them and have a hose that vents them to the outside of the trailer to keep any fumes from getting near a spark or into the interior of the trailer
2008 WW FS3000 triple axle, 16" wheels, Aluminum siding.
2006 Ford F350 SRW CC/LB 6.0PSD/Auto 4x4 18" wheels/tires
11,500 GVWR
23,000 GCWR
2000 Jeep TJ 4.0/5-Spd 5.5" RE LA lift, 35" Tires 4,440lbs
www.lonestarjeepclub.org
McKenziek
Visalia, Ca
To get rid of the sand encrusted slime that develops on top!
'08 WW CR3705, '07 F350, '07 YFZ450, '06 Rhino, '05 DS650
My Photo Albums
PsnRebel
BShivers wrote: PsnRebel wrote: Whats the purpose of a battery box anyway? Cars don't have 'em.
I believe;
#2 makes sense, I wasn't thinking about it that way. my batteries in now way interfere with the interior of the coach, but i'm sure some do.
good point
DuneMe
Elk Grove, CA
Nice Box!!!
Thanks for the link!
I'm going to run my two 12v as long as I can then go to the 6v system.
I just ordered up the Solar System from Costco.com and it should be here next week. I'll install it and hopefully this works well enough to maintian the batteries. I don't expect to have any problems in the summer time. . . it is the winter when we use our heater that the batteries are pulled down with the heater fan.
I don't know if I'll go with four 6v batteries. That seems like more than I need as so far my two 12v have done well for me. I'm sure the extra reserve power is nice, just haven't needed it to this point. I've got the generator and don't mind running it. . . heck that's why I've got it. Nice set-up though.
2005 GMC Sierra 4X4
Duramax Diesel - Edge w/ Attitude / 4" exhaust / Cold Air Intake
45-gallon TransferFlow Tank
4" Lift
Air Bags
Weekend Warrior LE3905 Toy Hauler
TomPro Mini-Rail - Turbo Hayabusa
Raptor 700's for the Wife and I
250EX - Daughter's
AreYouKiddingMe
SoCal
Can I get away with having just 2 6v batteries. I see more and more people going with a 4 6v battery set up. Is the main reason to gain capacity when the generator isnt running?
bertman911
Az
I used my 4 battery 6v setup last weekend and noticed a big difference in reserve capacity. Didn't have to use my heater at all, but still was always in the green (or good) range the entire trip only running the genny occasionally during the evening to assure a full charge. This years ELK hunt in November will be a true test to see their potential. Will post feedback when I get my trophy......
2008 WW LE3305
smkettner
AreYouKiddingMe wrote: Can I get away with having just 2 6v batteries. I see more and more people going with a 4 6v battery set up. Is the main reason to gain capacity when the generator isnt running?
You don't need four unless you need four. Often four go in if you use an inverter to power a tv for a few hours, run the furnace 24/7 in cold temps and use a portable generator etc. Also depends on how well the group conserves power.
Two will work perfectly fine.
AreYouKiddingMe
SoCal
I pretty much only use my th at the desert, with an occasional trip elsewhere. Just the wife and I 99% of the time, anything im sure is better than the single 12v we have now.
hotrod4x5
Fulltiming Southwest USA
AreYouKiddingMe wrote: Can I get away with having just 2 6v batteries. I see more and more people going with a 4 6v battery set up. Is the main reason to gain capacity when the generator isnt running? Two 6volts will outlast a 12 volt, or even two 12 volts by a few days, so yes, it is a good option.
Rodney 2005 Laredo 29GS 2002 F250 V-10 Hughesnet Satellite Internet
