RV.Net Open Roads Forum: Toy Haulers: 6v Battery setup help
Search only in Toy Haulers
 > 6v Battery setup help
bertman911
Az
Posted: 05/25/08 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
I just setup my 6v battery bank in my hauler, and want to make sure that my plans on wiring it are correct. I made a generic pic in MS Paint, but cant get it to load into a message. The process seems to be a hassle for this newbie.
Is there an easier way to load a pic into a message here or can I email someone directly to look over what I have and give me some advise or reassurance?
Thanks A Lot!!
2008 WW LE3305
Broccoli1
Los Angeles
Posted: 05/25/08 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
Ya can't attach photos from yer 'puter on this forum-ya have to link em' from a Host site
06 F250 V10 SB 4x4 Gulp Gulp
WW FSC2800
Rincon 650, Rhino
Power Wheels 750
"Shoot, I'm the world's best backwards driver!"
smkettner
Posted: 05/25/08 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
As long as you create a 12 volt battery by connecting the two batteries positive to negative you are ready to go. Then connect the cables to the open positive and negative terminals same as they were on the previous 12 volter. Nothing should be on the interconnect cable that joins the two batteries.
hotrod4x5
Fulltiming Southwest USA
Posted: 05/26/08 12:57am Link  |  Quote  |  Print  |  Notify Moderator
How many batteries do you have? I have four 6 volts. YOu just connect two so they are like one giant 12 volt, with an empty pos and neg. Then you take the two pos left over and connect those together, and the two negs that are left and connect those.
Rodney 2005 Laredo 29GS 2002 F250 V-10 Hughesnet Satellite Internet
JRBurn
Lake View Terrace, Ca. U.S.A.
Posted: 05/26/08 08:26am Link  |  Quote  |  Print  |  Notify Moderator
Here's a pic of my setup..............
06 Dodge CTD Quad Auto DRW 4X4, 4.10 & Exhaust break.
08 Weekend Warrior SLC 3905 Dual Slide
05 Polaris Ranger 4x4
05 Yamaha YFZ450, 04 Susuki Z400
06 Honda 250EX
CORVA, ASA, Action
bertman911
Az
Posted: 05/26/08 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Well sounds like I did what I was supposed to, and everything works. Hooked up 4 U2200's and seems to be okay. Might try to get some heavier guage cables someday, bit for now all is a go.
Thanks everyone for the useful info!!
McKenziek
Visalia, Ca
Posted: 05/26/08 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
JR! You found a battery box that will fit 4 6's in the WW. Please give me a link where you got it please. and thanks
'08 WW CR3705, '07 F350, '07 YFZ450, '06 Rhino, '05 DS650
My Photo Albums
smkettner
Posted: 05/26/08 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
Fisheries Supply quad box
Allied Battery quad box Quad GC2 box: 15 3/4" x 22 1/2" x 13 1/4" High
hotrod4x5
Posted: 05/27/08 12:36am Link  |  Quote  |  Print  |  Notify Moderator
I have the Allied box in my 5th wheel and it is a well made, strong, quality box.
JSGrewal
Simi Valley, CA
Posted: 05/27/08 10:22am Link  |  Quote  |  Print  |  Notify Moderator
I think those are just run of the mill plastic bins from Office Depot with the lids removed. The other post with the Allied fisheries link has boxes, but they still wouldnt fit in my WW. I moved the propane tanks over and rotated them 90 degrees, then made a new shelf for 4 batts without a box.
2004 F350 4x4 Crew Cab PSD
2007 Weekend Warrior LE3505+6
