RV.Net Open Roads Forum: Class C Motorhomes: 1984 Itashsa Sundancer 23 feet
 > 1984 Itashsa Sundancer 23 feet
omygod
portland oregon
Posted: 05/26/08 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Hi everyone, I,m looking for the good and the bad concerning a
1984 Itashsa Sundancer C class 23 feet. I have been doing a lot of searching and finely found one at a dealer.It has all the maintaince records sense new. The motor home has been well maintained, new 400ci Goodwrench motor and 400 trany all new ,fridge , tires, stainless steel roof,rebuilt gen., new wiring and pluming.I talked to the couple that owned it, they said they had all this work done so could go back east, however the oil cartel and the housing slump has canceled their planes. They had to move into a apartment and had no place to park the RV. I paid 8000 for this unit. If you have any experence with one of these please reply. Thank you Tom from Portland Oregon
OMYGOD YEP ANOTHER NEWBE GETTING READY TO GO FULL TIMING
Gale Hawkins
Murray, KY
Posted: 05/26/08 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds it it has one MAJOR problem the PO's could not solve. IT NEEDED A DRIVER. Make sure the roof seams do not leak anywhere and your big stuff should be out of the way for 10-15 years.
Deals like this happens all of the time but often you are the second one to learn about them.
omygod
portland oregon
Posted: 05/26/08 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the information Gale, however I am the third person to know,
I had a RV teco spend two hours going over this unit. He said to replace the graphics on the outside.
Thanks again Gale Tom from Portland
Gale Hawkins
Murray, KY
Posted: 05/26/08 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
That is good you got it checked out and they found not functional issues. Just in case you have any overheating issues take a look at the radiator but there is a good chance they had it checked out when they replaced the engine.
What a lot of people do not understand if a MH is dry (non leaker) the chassis can be rebuilt. For a little money you can make the wheel bearing and brakes at each corner like it was in 1984. Since you have the records you can go through system by system and check out any area that do not show to have been addressed of recent. Often a gas tank of that age can have a lot of trash/rust in it but again that may have been addressed or just not an issue. By the way what engine was it with 400 ci. Was it the 396 common in that era?
Ramblin_Mo
Mid-Missouri
Posted: 05/26/08 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
The THM 400 transmission is still used in US Army humvees according to Wikipedia. I have one, but I wish it had an overdrive.
http://en.wikipedia.org/wiki/Turbo-Hydramatic
Jarlaxle
New England
Posted: 05/26/08 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Last I saw, HMMWV's made after about 2000 use the 4L80E, not the TH400.
John
1984 Ford B-700 school bus conversion, Thomas body
A bunch of other vehicles
3 nutty cats (Maya, Vierna, Briza)
One lazy dog (Marmaduke)
One wife (Liz)
"A wasted youth is better by far than a wise and productive old age"
-Jim Steinman
