RV.Net Open Roads Forum: Dinghy Towing: Toyota Odometer
Search only in Dinghy Towing
 > Toyota Odometer
tominflorida
Jacksonville, Florida
Posted: 05/26/08 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Purchasing a new 2009 Toyota Corolla automatic. Will be towing on a dolly. Will my odometer rack up the miles with only the rear wheels on the ground? Toyota service was unable to answer this question?????
lostmarbles
Sacramento, CA., USA
Posted: 05/26/08 09:25am Link  |  Quote  |  Print  |  Notify Moderator
Really!!!??? They do not have their's system yet for the 2009 models? It used to be that they are comparable in group of 4 years. I'm not sure if they still do that. But if so, then are the 2008 the same setup? If so, where is the speedometer at in the 2008 manuals or models? If I remembered correctly, they are normally in the drivetrain area being electronic now and all. Which means, it should be a front wheel drive and it's up on the dolly... Unless the ABS are reporting movement on rear wheels now to the ECU. JMHO!!!
pulsar
Lewisville, NC
Posted: 05/26/08 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
debandi
Enjoying Life in Marathon, Texas
Posted: 05/26/08 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
I think that Corolla is front wheel drive so, with the front wheels on the dolly not rolling along on the ground there can be NO miles racking up.
We towed a 2002 Corolla manual trans 4 down and the miles piled up pretty quickly.
good luck and enjoy your ride.
John and Debra Spear
1999 Holiday Rambler Imperial 40PBS
2006 Saturn VUE toadReady Brake
A Closed Mouth Gathers No Foot
JaBob
Roswell, Georgia
Posted: 05/26/08 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
My 07 manual Corolla does not record milage when key is turned to first click.
Bob
 > Toyota Odometer
