googirl
austin texas
we just returned from a 4 day beach trip in our 2008 jayco jay feather lgt. The toilet smelled horrible the entire time! We called the dealer, and they suggested that we make sure that there is water in the bowl at all times, which we did. It still smells horrible, even after dumping and adding aqua chem. Any suggestions?
Hornet28BHDS
Parker, PA
It sounds like you may have a bad seal. Take the TT to the dealer for a thorough inspection.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
googirl
austin texas
Could the seal be bad and still hold water in the bowl?
Mr. Camper
ARKUSA
You might also want to check that the "door" was able to close all the way.
Mr. Camper
Mrs. Camper
Tipper, PoLar, Ginger (Our fuzzy kids)
2004 Dodge Ram 2500 5.9TD HO 4x2 Quad Cab SLT SWB
2005 Fleetwood Prowler Regal AX6 300FQS
fordsooperdootydieselsmoker
OrangeCountyCalifornia
Try a different tank deodorizer, Walmart has several liquid types, including an Orange one that works well. Enzymes help reduce the waste. Also, look at RV360 as a possible solutuin, works great for us!
bsimonds
Winnsboro, TX, USA
The vent out the roof may be blocked or may never have been connected during construction.
Bill Simonds
'07 Maxlite 28RL by R-Vision
'08 Armada LE 4X4
Hensley Arrow hitch
TruControl brake controller
jls
canastota, ny
It is also possible that the black water vent pipe is installed improperly. The vent tube sometimes is put too far into the holding tank and causes the lack of proper venting. Your dealer should be able to identify and rectify the problem.
john and Pam
2006 Chev K1500 Z71 4x4 5.3L
2002 Sunline Solaris T-2553
#24 TO THE FRONT
skipnchar
Topeka Kansas USA
A properly functioning RV toilet will have NO odor whether you use toilet chemicals or not. It may have a non functioning vent system, it may have a very dirty tank (not using enough water or dumping when tanks are not close to full can cause this). Good luck / skip
PatSak
Orlando, FL
If you camped at a campground with full hookups and left the dump valve open. you will get odors from the outside dump tank. I close our dump valve and only open every other day to dump and use the blue stuff. Never have any odors.
2008 Trail-lite 8308S
2006 Dodge Ram 1500, V8,
5.7L hemi engine, 4.10 rear axle ratio
2 Siberian Huskies
