Spott
48197
I saw this in the store today and want to know if anyone has first hand experience with it?
Does it work and if so how well?
Would you buy one again?
It would be nice to know when the first tank is low or empty (especially in the winter) with out having to go outside, unhook the tank and guess the weight.
Me - Kim - Spot
2005 204 ssi on the water - TCM article
Dick_B
Palos Heights, IL USA
We stopped worrying about it. We move the lever to the curb tank and when it is empty switch over the the street tank and refill the empty one.
You might trying pouring hot water over the tank while gas is being used to indicate the level if you really want to know.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
fast.5
Ontario, Canada
Hi Bruce: Can't help you on that one but for $79 you could get one that works for sure, think I will next year when we are down there, unless you find that it works.
Mike
Go to manchester tanks, they have 20 and 30 lb tanks with gauges
2004 FORD F350 Supercrew 4x4 V10 Airlift incab controls 42" titan extension camera.
2004 LANCE 1161 Loaded, Air, fan, Dicor and all weather packages Awning&Slide awning 50W solar 36lp Plus Generac
Fast.5 Reno Page http://community.webshots.com/user/fast5
bigjimcruising
Orange County, CA
I have a similar gauge on my tanks, no remote indicator though. While they will give some idea of whats in the tank they really don't help much. Problem with propane is the gauge changes all the time depending on external temperature. Sometimes the gauge will show the tank full, then later that day show it almost empty. The only thing that changed during that time was the ambient temperature. Plus the gauge will show full with just a little down swing until the tank is almost empty, then suddenly will drop into the yellow range. Overall it's not much help, just a guide to tell you when your empty. If I had it to do over again knowing what I know now I wouldn't waste my money. But if you do buy it let us know how it works for you! Good luck!
2007 F450 4x4 Extended Cab, 6.0 PSD AT, 9ft Flatbed with 8ft boxes. Okanagan 117DBL, loaded. 13ft tall! Happy Trails!
Steve_in_29
29 Palms (SEMPER FI), CA 92277
Costco has the BBQ style tanks with a built in gauge (float type not pressure) in stock for $27.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
kcabpilot
CA
With dual tanks and auto switch you run off the tank without a gauge first. When it runs out you will know by the switch indicator. At that point you have your gauge but, as has been said, it's not an exact indicator. You do know that you are less than half though so it's time to at least start thinking about getting a refill.
I don't know about the remote gas sensor but I would think the most reliable method of knowing how much propane you have would be a weight scale but that wouldn't work for an RV since the tanks are clamped down.
Works on the Weber though...
1994 Lance 990 on 1997 F350 PSD Dually
We also have a 'truck' that FLYS
Our 2008 trip to The Canadian Rockies
Steve_in_29
Marshall makes a remote change-over indicator and I installed one on my camper. While it won't tell you how much is in the tanks it does let you know when the primary tank is empty so you can look for a place to get it filled.
Only downside is that it runs off of 2 AA batteries and has no on/off switch, so you need to remember to remove the batteries when you store the camper other wise once the LP leaks down from the hoses the indicator will start flashing and eventually deplete the batteries. Also the indicator will continue to flash as long as you are using the secondary tank. It will only stop when the primary tank is refilled and the change-over lever is flipped back to the primary tank.
rjsurfer
North Carolina
Another piece of Chinese crap...as others have said the gauge fluctuates due to external temperature.
Weighing the bottle is the only true way of telling the amount of propane left.
Ron W.
03 Dodge 2500 SRW,SB,EC
2008 Keystone Cougar 245RKS 5th Wheel
DRZ-400SM
DL-650
AidenJ
Adirondacks, NY ,USA
Some one at one of our rallies had a clear (see through tank) I don't recall who it was or anything about them. That would be the ultimate gauge.
"04" CHEV 2500HD DURAMAX DIESEL REG CAB SRW
"03" LANCE 1025
12 YR OLD BORDER COLLIE
54suds
adk mts.
lite cyl.
05 Ram xcab drw 4x4 4.10... 06 Bigfoot 25c10.6e....
