RV.Net Open Roads Forum: Travel Trailers: Need Information 27BH G2
 > Need Information 27BH G2
Hemisport
Prince George BC
Posted: 05/26/08 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
I just noticed I have a screw starting to come up near my heat duct in the center of my TT. It has not broken the linoleum yet but will soon. I am going to take it to the dealer tomorrow what should I be ready for. Will they fix it now or wait for it to break through..
KnLMurakami
Acton, CA
Posted: 05/27/08 11:43am Link  |  Quote  |  Print  |  Notify Moderator
We have the same problem with our 23FB. It was a staple coming up. DH pulled the floor vent and looked under vinyl (it's not glued down). Used a screwdriver to pop the staple loose and replaced the vent. Pretty easy fix if you have the access. Good to catch it before it pops through the vinyl flooring and easier than taking it to the dealer.
2008 Jayco JayFlight G2 23FB
1996 Ford F350 Crew Cab 4WD 7.3 IC
Equal-i-zer 10K
Hemisport
Prince George BC
Posted: 05/27/08 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
Mine feels like a screw. I know the lino is not glued down, But I would rather the dealer fix. I will do little stuff but if there is a possibility of a mishap I will get the warranty to fix it.
Hornet28BHDS
Parker, PA
Posted: 05/27/08 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
The dealer should take care of you. Keep us posted!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
