RV.Net Open Roads Forum: Towing: RV Fire Downtown Toronto
Search only in Towing
Open Roads Forum  >  Towing
 > RV Fire Downtown Toronto
shum02
Burlington, Ontario Canada
Posted: 05/28/08 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
What can happen when your tires blow out.
Toronto RV Fire
2007 F150 XLT CC 4x4 5.4L 3.73LS
2007 KZ2505QSS-F Outdoorsman
Camping Pic's and Mods
More Pics & Mods
reno82
Cardiff by the Sea, CA
Posted: 05/28/08 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Quick thinking to pull those propane bottles off.
USAFBILL
Alabama
"The driver managed to flee the burning vehicle and took a propane tank off the RV to prevent an explosion." Wonder how he did that?
grampachet
West Coast
Posted: 05/28/08 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
Is this a reason to travel with propane valves turned off? hummmmmmmmm
2004 F-250 KR,CC,SB,SRW,4x4,V-10,3.73
2008 Montana 3000RK
rhillx4
Huntington Beach ,CA
Posted: 05/28/08 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Well Thank goodness he thought about getting the propane tanks off. That was quick thinking. And I guess I will not have the fridge run on propane just incase I have a tire problem.
2002 Dodge Ram 1500 Quad-Cab
2008 Jayco JayFlight 26BH
Garfie|d
South-Western Ontario
Posted: 05/28/08 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
Forget the propane, can driving on shredded tires generate enough heat to start a fire?
2001 Airstream Safari 25SS tugged by 2001 GMC Yukon 5.3L 3.73
Hensley Arrow • Jordan Ultima • Barker 3000 • Mckesh
BarneyS
S.E. Lower Michigan
Posted: 05/28/08 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not so sure anything would have happened if he had not removed those propane bottles. See the picture below of my former pop-up trailer after it burned in a barn fire. The propane bottles were full and you can see what remains of them if you look carefully. You can see the A frame, jack, and one propane bottle in the first picture. They did not blow up thank goodness.
Barney
* This post was edited 05/28/08 04:42pm by BarneyS *
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the new RV.net Blogs!
Visit our website here
Don8ch
Mississauga, Ontario
I would assume the tire shredded as a result of a brake or wheel bearing problem that would have created a lot of initial heat that transferred to the tires.
2005 GMC Sierra 2500HD SLT Crewcab 4x4,
Duramax/Allison, Michelin 265 LTX/MS
Pullrite Superglide, Prodigy
2006 Pilgrim 335RLSS-5
reno82
Posted: 05/28/08 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, especially for a dually. I saw a tractor trailer set a forest fire over a 1/2 mile swath of road. One of his rear tires blew out and started a fire throwing burning rubber as he kept driving.
Perrysburg Dodgeboy
Perrysburg, Ohio USA
Posted: 05/28/08 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
A propane bottle will not explode in a fire; the pop-off valve will open and dump the fuel out in turn adding fuel to the fire but no explosion. We routinely lit a 500# propane tank when I was on the fire department for fire drills and never once did it blow up.
Don
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
pics
