RV.Net Open Roads Forum: Towing in the hills, let the speed drop or step on the gas?
Search only in Towing
Open Roads Forum  >  Towing
 > Towing in the hills, let the speed drop or step on the gas?
Padlin
W. Ma.
Posted: 05/28/08 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
I have a question for some of you veteran travelers concerning which is better on the transmission when driving in hilly terrain.
Do you let the vehicle slow down as you go up hills then pick up speed on the down side to keep the transmission from down shifting, or... do you give it more gas when it starts to slow there by have it down shift and gain the speed back?
thanks
Bob & Deb
W Ma.
04 GMC 1500 4X4, 5.3L
06 Starcraft 18SB
moparmaga2
Lubbock, Tx
Posted: 05/28/08 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
I will let the speed drop if it is just a small hill. Anything larger and I will shift into a lower gear myself. I will not wait for the transmission to do it for me.
This way you can keep the RPMS up where you want them, instead of the engine lugging down, and then the transmission shifting.
The Moparmaga guide to cheaply living in a RV while attending College
Moparmaga.com -Trip, Campsite and RV pictures
dbbls
Missouri
Posted: 05/28/08 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
I let it slow down then barrel own when I get over the hill. I don't shift down until I get below 50.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
donn0128
Pronounced Ore-gun
Posted: 05/28/08 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
Transmission does not care what gear it is in. Keep the motor spinning in it's RPM range for best performance/economy
Donn
rhillx4
Huntington Beach ,CA
Posted: 05/28/08 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto same thing we do.
2002 Dodge Ram 1500 Quad-Cab
2008 Jayco JayFlight 26BH
'68Monaco440HP
Corpus Christi, Texas
Posted: 05/28/08 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
As everyone else has said, let it tell you what it wants. If you have a vacuum gauge, downshift by that versus engine rpm drop as it's faster, more accurate and better for the drivetrain. Bottom line is that you and the vehicle have to work some.
Grandad's Dodge Monaco & 1966 28' Streamline
@11,300#; 10 mpg solo & towing
Parents: '76 Cadillac & 1975 28' Silver Streak
12,900#; 8 mpg tow, 12-14 solo
Us: Dodge CTD 6-spd; 1983 34' Silver Streak
15,750#, 13-15 tow, 19-22 solo
Padlin
W. Ma.
Posted: 05/28/08 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
How does one determine the optimum RPM to keep it at?
mrad
Zimmerman, MN
Posted: 05/29/08 06:32am Link  |  Quote  |  Print  |  Notify Moderator
I would like to know optimum RPM range also. My 5.7 GM makes peak torque at 2,800 RPM's. Does that mean I want to keep it at 2,800 RPM's on hill/mountains? It seems a lot of people are with gassers are towing in the 4,000 RPM range when climbing steep hills. Don't you lose torque when you go above the peak torque RPM's?
loufish
Burbank, CA
Posted: 05/31/08 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
That's me...
That's correct, different engines have their own optimum torque range...You 5.7 is a "mid range" engine, that is it makes it's max torque kind of mid way in the rpm range. The Dodge Hemi and Chevys 5.3 are "revers" that make their max torque at around 4000 rpm and are designed to run in that rpm range when needed to.
You are also correct in stating that reving an engine past it's max torque rpm means the torque actually starts dropping...but most of the time when an engine is running those rpm's the trucks in a lower gear to get the mechanical leverage it needs to climb a hill...a gear low enough that the truck can pull up the hill with less then the max rated torque needed, but the extra rpm is now used to keep up a desired speed.
In other words, when you drop your truck down to 2nd gear to climb, you don't need full throttle because the gear is so low, but if you want to tow faster you give it more throttle and rpm...
To answer you original question about you 5.7L, I wouldn't run it at 4000 rpm or more for any length of time...
I'm sure I'll hear replies on that one...
* This post was edited 05/31/08 07:48pm by loufish *
"I won't camp next to you, if you don't camp next to me!"
2004 Titan King Cab, 2wd, 5.6L V-8, 5 Speed Auto Trans, Tow Package.
2004 Jayco Qwest Baja P/U
2002 Honda XR650R
PrivatePilot
Courtice, Ontario, Canada
Posted: 06/01/08 09:01am Link  |  Quote  |  Print  |  Notify Moderator
I'll back out of it on any hill where I know there's a possibility of the transmission staying in 4th/lockup if I do so, but then again I'm a diesel guy so letting it work down into it's torque curve is beneficial versus downshifting and letting it roar up the hill on horsepower alone.
If there's zero chance of it pulling a grade without downshifting then I'll usually still back out of it anyways until the downshift occurs, and then put my foot into it to maintain whatever speed it downshifted at.
I could leave it on cruise control and maintain highway speed up allot of grades, but it costs more fuel, and I'm seldom in that much of a rush. If someone else wants to tear by me at 75MPH getting 2MPG up a grade while I pull a grade at 55MPH and get three times that, then all the power to them - I'll be passing them again at the next fuel stop.
* This post was edited 06/01/08 09:08am by PrivatePilot *
30' Keystone Cougar 5'er, Triple Bunkhouse, SuperSlide.
Chevy 3500 1 Ton long box crew cab dually
6.5 Turbo Diesel, 4.11 Rears, LSD.
Checkout my blogs, adventures, and more here!
Mark
