jparker66
Rockwall, Texas
Has anyone used a cordless drill to more easily put up and down the scissor jacks? If so, what kind of drill. My 18v would not do the job.
Thanks
James & Sharon
2006 Holiday Rambler Savoy SL 29'
2004 Dodge Quad Cab Hemi
CAMPING IS GREAT! ENJOY THE OUTDOORS!
spepi
Mansfield MA
I did for the first time this weekend. I used my 18v Dewalt and it worked like a charm...brough them down snug, and did a half turn by hand....easy down, and easy up....try greasing the spindles with some heavy grease, and run them up and down by hand a few times, then try the drill again
DW, 2 Teen's, 2 Dogs
05 Chevy Trailblazer (I know...its small)
3.42 Gears
Prodigy Brake Control
Reese 800lb Weight Dist Bars
Dual Cam Sway Contol
2008 Rockwood 2701ss
agesilaus
North Florida
Yup, just got a Harbor Freight cheapie 18v cordless($19). I had to switch to the high torque setting but it works just fine with a 1/4 inch hex wrench in the chuck. The high torque setting (one click below the drill holes setting) will drive the jack down against resistance.
It will reduce the whining from my 10 year old since that was one of his CG arrival chores. I'd rather listen to the drill whine than the 10 year old whine...heh.
BK
04 Trail Manor 2619
08 Ford F150 5.4L TV
fla-gypsy
North Florida
I use a Kawasaki 19.2v, works great.
05 Super Duty XLT CC 5.4/3.73 5 sp auto Torqshift
06 Keystone Hornet 29 RLS/(The"Cracker Cabana")
Reese HP Dual Cam
Camping Photos
Northeast Florida Camping Club
St Andrews SP cult member
Campinfan
Washtenaw County, Michigan
spepi wrote: I did for the first time this weekend. I used my 18v Dewalt and it worked like a charm...brough them down snug, and did a half turn by hand....easy down, and easy up....try greasing the spindles with some heavy grease, and run them up and down by hand a few times, then try the drill again
Ditto. That is exactly what I do and it works.
________
2008 F 250 FX4 4WD, V10, 4.10 Tow Command
35' 2007 Crossroads Cruiser CT32SB
Wonderful Wife and 3 small kids
dclark1946
Richardson,TX,USA
I use a Black and Decker 14V drill set to high torque and it works fine. You may want to spray the jack threads with WD40 to reduce drag.
Dick
Dick & Karen (converted tent campers)
Richardson,TX
2007 KZ Spree 240RBS
03 Tahoe/04 F250 PSD
grump daddy
Westland, MI
I use an 18v cordless also and works good. As stated above you may need to lube them up good to get them loose, however I don't think I would use a heavy grease as it could pick up a lot of road grim and make them even harder to work. Try using a silicone spray to lube them. I think that would pick up less grim in the threads. Also make sure that you lube the pivot points to as they will rust a little over time.
Bucky Badger
Madison, WI
I use a Bosch 18Volt...GREAT
Fred & Jodie, dogs, Zoey & Bella
2007 Nissan Titan, 5.6L Big tow, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
Member Titantalk.com
Nights camping 08 (43)
Rallies/Gatherings
IL
WI
Bonefish
Midland, TX
Dewalt 14.4v has been working fine for doing this since 2003.
Hornet28BHDS
Parker, PA
I think an 18 volt would do the trick. Try to grease the jacks and see if that helps.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
